Old 01-01-2007, 09:03 PM   #1 (permalink)
╬Switch╬'s Avatar
Exclamation PHP Live Counter problem!!
I got this code from webdesign.org it does work,
//DBase Name:
$opt_connected_cfgbase = "base";
//Username :
$opt_connected_cfguser = "user";
//PassWord :
$opt_connected_cfgpass = "pass";
//Path :
$opt_connected_cfghote = "localhost";
// Amout of time to consider a user active
$nb_connected_connexion=300; // 5 minutes
// Connexion to the database
$base_connected=mysql_connect($opt_connected_cfghote, $opt_connected_cfguser,$opt_connected_cfgpass);
if (!$base_connected)
("<center>Error connecting to the Database </center>");
exit();
// Database selecting
if (! mysql_select_db("$opt_connected_cfgbase",$base_connected))
mysql_close($base_connected);
print("<center>Error connecting to the Database</center>");
exit();
// time
$time_connected=date("U");
// Get IP
$ip_connected=$REMOTE_ADDR;
// Search IP in the DB
$query_connected="select * from nb_connected where ip='$ip_connected'";
$result_connected=@mysql_query($query_connected,$base_connected);
if (!$result_connected)
print("<center>Could not execute request </center>");
exit();
$nb_connected=@mysql_num_rows($result_connected);
if ($nb_connected)
// Update the connexion
$query_connected="update nb_connected set time='$time_connected' where ip='$ip_connected'";
else
// Create connexion
$query_connected="insert into nb_connected (ip, time) values ('";
$query_connected.=$ip_connected;
$query_connected.="', '";
$query_connected.=$time_connected;
$query_connected.="')";
// Calculate maximum time of connexion
$time_max_connected=$time_connected-$nb_connected_connexion;
// Deleting Maximum time connexion from DB
$query_connected="delete from nb_connected where time<'$time_max_connected'";
// Close connexion to DB
But it is displayed along with the following error:
Notice: Undefined variable: REMOTE_ADDR in d:\web\tools\easyphp\www\counter\index.php on line 35
Can anyone help me get it right
There are 10 types of people. Those who understand binary and those who don’t…
╬Switch╬ is offline
Old 02-01-2007, 08:15 PM   #2 (permalink)
Default Re: PHP Live Counter problem!!
Hello there,
Use,
$_SERVER['REMOTE_ADDR']
instead of
REMOTE_ADDR
Hope this helps you out.
Regards
Utsav HAnda
Ur\'s
Utsav Handa {:-)
utsavhanda is offline
Old 03-01-2007, 06:27 PM   #3 (permalink)
tuxfan's Avatar
This needs a MySQL database. Hope you have created one and connected with this! However, I have seen simpler PHP counters that don't need a DB. They are lighter on the system.
tuxfan is offline
Old 07-01-2007, 09:13 AM   #4 (permalink)
╬Switch╬'s Avatar
@utsav handa:
Ill try that.Thanks.
__________
@tuxfan
The couneter I have above counts the number of people online at that instant.
The ones you mention (ones which are made using text files) count number of visits to a page.
╬Switch╬ is offline
Old 08-01-2007, 04:47 PM   #5 (permalink)
tuxfan's Avatar
Ah ok That one is also a useful indicator.
tuxfan is offline
Old 14-01-2007, 12:21 PM   #6 (permalink)
╬Switch╬'s Avatar
@utsav handa:
Thankx
$_SERVER['REMOTE_ADDR'] worked!!
╬Switch╬ is offline
