I need to feel my command prompt in windows xp look like ms-dos in win98. while working in cpp or c. the output looks text in small condensed format . i need to look like win98 . what is the settings.
can anyone help me.
well you can right click on the blue title bar and go to properties to adjust fonts.
WIndows XP command prompt wont look exactly same as 98, its not even real command prompt.
The best way is make a bootable dos floppy. Have 1 partition as FAT32.
Copy your TCC folder to that partition, boot from the dos bootable floppy and run TCC there.
Thats what I do.
