My friend got a cd free along with a text book. While viewing the cd there was a loud sound and the cd had become pieces inside the drive itself. What could have been the reason for this?
And a bit of Bad Luck too ..
You should have your drive cleaned to make sure that no pieces of the CD are left in the drive ..or they will mess with the lens ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
Dii you place the Cd properly in the cd tray??? or the other reson may be some one has fooled u and has put up a CD mixer in place of the CD-ROM .
..:: peace ::..
Jeba
U are not alone In the List.
I had The same problem too. 8)
But Ot Was complitly My Fault.
I Had put a Broken Media For Experimental Purpose.
Well ofcorse I had the Warrenty
Either the cd had a hairline crack / didn't place it properly in the drive / extremely bad quality of cd.
__________________ DON\'T waste money on expensive ipods. Simply think of your favourite tune and hum it. If you want to \"switch tracks\", simply think of another song you like and hum that instead.
m8 whatever has happened has happened but now your priority should be to get it serviced by a experienced proffesional else you ma end up shelling out 1000rs for a new cd -rom drive
__________________ \"I was born INTELLIGENT
But EDUCATION ruined me!!!!\" AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
The thickness of the CDs should be same at all points.Low quality or Cds with manfacture defects have varying thickness.Event though this is unidentifiable by us,at very speeds in CD Drive,this varying thickness causes imbalance and hits the parts of the CD Drive causing the CD to break.
