Old 10-01-2005, 01:55 PM   #1 (permalink)
Default Tricky problem: HDD issue?
Hi,
since yesterday my PC has stopped booting. It just stops/hangs after the POST.
Its a P4 1.7 GHz, 256 SDRAM, nVidia GeForce 2MX400 64Mb 4x card, all this on VIA Chipset Mercury board .
What could be the problem. there was a checksum error once, but after setting all the options, it gives out the normal beeps. HDD is fine. checked it on my other PC.
Why fart and waste it, when you can burp and taste it!
SpitefulPentium is offline
Old 10-01-2005, 01:59 PM   #2 (permalink)
swatkat's Avatar
If there is CMOS checksum erro,then u have to replace the CMOS Cell.
If that's not the case,then check ur RAM,that is remove the RAM Modules and clean the slots by blowing air and put the RAM back.
http://swatrant.blogspot.com/
swatkat is offline
Old 11-01-2005, 10:12 AM   #3 (permalink)
Hi,
I checked both. no problems there. (cos I had disabled quick boot. This checks the RAM when booting and would have given a long beep to indicate RAM problems)
Now here's a funny thing. I cleared the CMOS, it gave a CMOS error. I DISABLED everything (IDE,USB,Modem,LAN,Sound etc) and then after POST it did not hang. I rebooted and enabled one thing at a time and found that the PC boots through a CD/Floppy but does not boot from the HDD. the HDD is perfectly ok. checked it on my other PC. I even interchanged Primary and Secondary connections to make HDD sec and CDdrive Pri. scandisk results ok. fdisk shows everything to be ok.
whats the problem here?
Old 11-01-2005, 10:41 AM   #4 (permalink)
NikhilVerma's Avatar
Most probable there has been some other internal damage....(Do you keep your cabinet open?)
Or a virus maybe....
I think that you should send your board for repairs...
NikhilVerma is offline
Old 11-01-2005, 11:11 AM   #5 (permalink)
no I dont keep the cabinet open.
virus.... I just formatted and reinstalled everything. plus got no internet connection at home
look like some kinda damage to the board.
I could try formatting once again and see if things work out.
Old 11-01-2005, 11:31 AM   #6 (permalink)
tuxfan's Avatar
Use a Knoppix or Gnoppix CD to boot and see if it boots properly. If it does, most of your hardware would be working properly. Check the sound as well in Knoppix.
Secondly, the IDE cable of your HD may be malfunctioning. So replace it and check.
tuxfan is offline
Old 11-01-2005, 11:49 AM   #7 (permalink)
I forgot to mention about the cables. Yes I did replace them and check things. Same problem.
And I booted using a bootable CD (DOS). Hmmm.
Old 11-01-2005, 03:16 PM   #8 (permalink)
try with removing the keyboard,nd then booting...
it helped me once,kboard was malfunctioning...!!
grinning_devil is offline
Old 12-01-2005, 09:34 AM   #9 (permalink)
tried everything. no progress.
could the psu be the culprit?
EDIT: If it looks like a total gone case, does anyone know where i can get the mobo repaired in Pune. (No suggestions for an upgrade please )
its a VIA chipset Mercury board for P4.
Thank you all.
