Old 10-01-2005, 12:58 AM   #1 (permalink)
Default System getting restarted suddenly !!!!
hi
My system is getting restared without my control when i am on a internet session especially when using yahoo messenger!!
i am using win 98 os ,norton2004 antivirus, and norton internet security 2003 also.
wat cud be the problem can anyone suggest??
muralidharan is offline
Old 10-01-2005, 10:54 AM   #2 (permalink)
geek_rohit's Avatar
Looks like a virus. Run a full system scan. If there is no virus then reinstall Yahoo Messenger. If even this doesn't solve the problem then keep a check in this post for an answer.
SportZForumZ - We Know Your Game Better
http://www.sportzforumz.com
My Site & Blog
http://www.rohit-sharma.com
geek_rohit is offline
Old 10-01-2005, 11:03 AM   #3 (permalink)
I doubt its a blaster worm...yeah it once happend to me also. rather than full system scan.....
Must Do !
1) Update Virus Protrection.
2) get Spy Boot (Google Search)
3) Reg Cleaner (-do-)
there r lots if i mention so..lets not create a zig zag in herere ... This is will keep fit and healthy of ur Buggy Computer .
Flip like a butterfly, sting like a bee
Butterfly is offline
Old 10-01-2005, 12:00 PM   #4 (permalink)
tuxfan's Avatar
I have faced a similar problem earlier. It can your Power Supply or Stabiliser as well. Have that checked.
tuxfan is offline
Old 12-01-2005, 11:20 PM   #5 (permalink)
Me also had same prob.Check out the coolin fan.It shud work else the system restarts.
Earth is full.Go home.
adorablesrini is offline
Old 12-01-2005, 11:49 PM   #6 (permalink)
i do agree with adorablesrini with temp.
check ur cpu temp in bios. should be around 37-45 i guess
snehal_prabhu is offline
Old 13-01-2005, 12:04 PM   #7 (permalink)
if this thing is happening only when u r using internet then i m afraid it can be blaster worm. r u getting any sort of countdown in that message like: ur pc is gonna shutdown in 60->59->58 ....... seconds,if yes then this is surely blaster worm. i think it can due to temp. problem too as described by others. Check temp. too.
Ashootosh is offline
Old 15-01-2005, 12:36 AM   #8 (permalink)
Default Reply 2 murali
Hello murali ,
If this is not hardware problem Iam sure it is SASSER .
try this ---start--->RUN [win key+R] --->type ---shutdown -a
after shutdown please give a space .
Then go to Microsoft.com & dwnld
patch 4 SASSER .and scan ur computer
Have a nice day THILAK
Thilak is offline
Old 15-01-2005, 12:43 AM   #9 (permalink)
yeah man sure the BLASTER worm.
Just swnload some blaster worm serch n destroy pack.
I hv 1.
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
