Old 30-12-2006, 09:50 PM   #1 (permalink)
dinesh_mettur's Avatar
Question How to create a own Website???
hi dudes
how 2 create a own website?? i know html,java script .
what is mean by phpbb???
___________________________
~~ THINK DIFFERENT ~~
.. U'r Ultimate Place To Enjoy ..
www.funisland.co.nr
dinesh_mettur is offline
Old 30-12-2006, 10:29 PM   #2 (permalink)
eWebGuru
ahref's Avatar
Default Re: How to create a own Website???
phpbb is discussion board (forum) software. If you want to make forum then use it.
If you are asking for php, it is server side script, used to make dynamic site.
Windows and linux hosting at http://www.ewebguru.com
Get $50 per blog post PM me for details.
ahref is offline
Old 30-12-2006, 10:41 PM   #3 (permalink)
Wise Old Crow
blueshift's Avatar
Just googled your question and i got this.
http://twitter.com/blueshift155
blueshift is offline
Old 30-12-2006, 10:54 PM   #4 (permalink)
The Devil's Advocate
iMav's Avatar
just as vbulletin is a forum software (now on digit) .... same way phpbb but only benefit is tht phpbb is open source and fukat
http://beingmanan.com
iMav is offline
Old 31-12-2006, 12:14 AM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
Originally Posted by dinesh_mettur
i know html, java script
coool...
  • Buy a Domain Name.... Rs. 400/-
  • Buy a 50MB cPanel hosting or u may look for free stuff too.. Rs. 1200 /- to Rs. 1500 /- or free
  • Google for a Template on topic which u want ur web site too.. Free
  • Use html and Java Script to build a static web site for ur self Free
  • Lots of Codeing has to be done
now if u are making a personal web site...
then,
  • use fantastico of cPanel to install a bloging script like WordPress Free
  • Use word press easy to use posting panel to start ur personal web site instantly... Free
  • No Codeing is required
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 31-12-2006, 01:37 AM   #6 (permalink)
Thanks for u r kind Reply dudes
Adv happy new year
www.funisland.co.nr
Old 31-12-2006, 01:15 PM   #7 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Maybe i can help because i have my Webhosting Business.
1. Buy a Domain like .com or .net. Can very from seller to seller. I sell .com for 7.95 for a year. Namecheap.com is a Good site which sells for 8.88 but look for COUPON codes and you will get a .80 cents discount coupon and Namecheap as great Service and what more you get WHOIS PRIVACY free for 1st year.
2. When you buy domain, you will be asked something called "NAMESERVERS". If you have buyed hosting already, you host will give you NAMESERVERS which in most cases are
ns1.*hostdomain*.com
ns2.*hostdomain*.com
You will need minimum two nameservers, PRIMARY AND SECONDARY. A host can have more of them aswell for differnt servers.
3. When the Domain is registered, you can either park it for the timebeing or enter the HOST's Nameservers. Enter Nameservers and you are done.
4. Since the Domain is new and just registered, the first DNS propogation will be like done in most cases under an hour.
5. After that, if in case you are unsatisfied with services of current Webhosts, all you have to do isbuy hosting from new hosts and enter their Nameservers in the Domain Control Panel.
DNS changes can take upto 24hrs.
Hope this helps. BTW if you need hosting, contact me.
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 01-01-2007, 04:03 PM   #8 (permalink)
tuxfan's Avatar
saurav_cheeta has given a detailed answer on the process and sukhdeepsinghkohli has given it in still more details
Usually this is the procedure:
1. Buy a domain (don't fall for free or cheap domain tricks)
2. Host it immediately if you want to use it for emails.
3. Build the site
a. Get a template
b. Write code
4. If you have not hosted it already, host it now.
Except domains, all the other things you will get it for free. Even in paid hosting, designs, etc. there are lots and lots of variations.
tuxfan is offline
Old 01-01-2007, 11:13 PM   #9 (permalink)
Rebooting
well Rs. 400 or 500/- is all most free when u can spent Rs. 500 to 900 PM for broadband, then u r expected to be able to save another Rs. 40 to 41 per month for a domain cost ??
anyway if u dont want to spend that little Rs. 40 per month, u may opt for a url redirector, such as .co.nr....
rebooting
ChotoCheeta.com
Old 02-01-2007, 09:43 AM   #10 (permalink)
speedyguy's Avatar
well url redirectors dun giv u d specific .net or .com or .org etc...names but will giv u some thing casual like....frag.it , .link.it, .says.it etc.
Enjoy~!
No Pain...No Gain
speedyguy is offline
Old 03-01-2007, 06:47 PM   #11 (permalink)
tuxfan's Avatar
Quite true! .com for about 1 rupee a day and .in under 2 rupees a day are real value for money. We should also consider that people know our site by our domain name. They don't even know where it is hosted.
tuxfan is offline
