Old 30-12-2006, 01:33 PM   #1 (permalink)
Wise Old Mouse
mrintech's Avatar
Question *** HELP ME out reGARDING JAVA ***
friends,
i need your precious and urgent help
actually i am a beginner @ Java. you can say that i know nothing about it @ all.
Simply suggest me some books (not e-books) for a beginner like me. which starts from the fundamentals and goes deeper and deerper.
moreover what are the software requirements for running JAVA/Java based applications.
Plz give out the links.
I repeat again I am a beginner and know nothing abt this language. really.!
Plz help out guys.
-wishes
- MrinTech :)
mrintech is offline
Old 30-12-2006, 02:00 PM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: *** HELP ME out reGARDING JAVA ***
Book : Herbert schildt
Software : Sun java compiler
Read the book u'll know urself what to do next!
mediator is offline
Old 30-12-2006, 03:58 PM   #3 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
Complete Reference to JAVA is one of the best books out there when it comes to learning it by yourself.
As for JAVA IDEs, I will suggest you go for Eclipse, but only after mastering the concepts of Java.
ctrl_alt_del is offline
Old 30-12-2006, 04:19 PM   #4 (permalink)
Still Shining!
Lucky_star's Avatar
^^Yeah, I too beginned with it. Its a nice book for grasping the fundamentals.
Nokia N86 8MP
Lucky_star is offline
Old 30-12-2006, 07:22 PM   #5 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
BOOK---> COMPLETE JAVA REFERENCE by Herbert Schildt (PM me if u need any help on this book)
S/ware---> JDK from www.sun.com or www.java.com or EDIT PLUS (search on google)
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 30-12-2006, 08:59 PM   #6 (permalink)
SE><IE
Posts: n/a
IIRC Complete reference is the book and Herbert shield is the author of the same.
once you get basics clear, or maybe even before that, google "java forums"
