Old 09-01-2005, 06:30 PM   #1 (permalink)
Default A 'File' Problem
Hi to every computer enthusiast,
Calling all computer geeks,
How can we convert a file with the extension 'File' to .exe to execute it?
I downloaded a file and it wont run because first, it asks me to select a program from a list to run that file and I cant find that program!!!
Is there a way to convert that file to .exe to run??
PLEASE HELP!!!
Joker1 is offline
Old 09-01-2005, 08:02 PM   #2 (permalink)
aadipa's Avatar
why didn'y u try to rename it first?
command line syntax
ren [oldname] [newname]
Or open the Windows Explorer, browser to the file. Right click and select rename. Just add the .exe extention and try to run it.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 09-01-2005, 08:07 PM   #3 (permalink)
What exactly is the extension of the file you are talking about.I suppose it is definitely not .file
Do I really need a signature to be unique?
allindrome is offline
Old 09-01-2005, 08:38 PM   #4 (permalink)
is it supposed to be an .exe file in the first place ?
give us file details and wat its actually supposed to be ... and a link with decription would be helpful
if its not supposed to be a .exe then renamin it wont help !
and plz remember to goto tools>folder options>view and disable "hide known file extensions" before u rename
No Mercy, No Limits.
theraven is offline
Old 09-01-2005, 11:28 PM   #5 (permalink)
What I got from your mail is that u have downloaded a file without any extension. So if u single click that file, on the left pane, the file type u will se is 'File'. So for that rename it to '---.exe' or whatever format it is in.
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
Old 14-01-2005, 12:26 PM   #6 (permalink)
Default well
well
i think he has misunderstood things
means may be he clicked on some file then the OS pop up a box to choose program and he thinks that to open in any program the file should be in *.exe format.
is that so (what he understood)?
or i mis understood it
an yway i think to be change to *.exe there are many soft for it and i dont feel like ok txt file need to be changed to *.exe (i have not used such soft..)
people usually change animation(avi,...to exe)
and some time zipped files making self excutable files...
be who u r :
Saharika is offline
Old 14-01-2005, 01:50 PM   #7 (permalink)
swatkat's Avatar
if u dont know the real extension exactly u can use this software called TrID to examine it and determine the correct file type.
Get it here.
http://swatrant.blogspot.com/
swatkat is offline
