Old 09-01-2005, 02:26 PM   #1 (permalink)
Default p2p and im security plzz help me guys
hi
thanks for your time , however pls suggest me on tools which can be used for p2p and im security , or which has p2p antivirus scanning options and im security options.
thanks is advance guys.
Vey happy new years guys
[/b]
hi to everyone.
avinashtatti@gmail.com is offline
Old 09-01-2005, 02:42 PM   #2 (permalink)
Default Avast is good
Well, for a P2P security and IM 's combined Avast is a good free option as it has options for both of them.
If you wanna try other choices go for a combination of Zone-alarm fire wall and antivir virus application.
Kaspersky is equally good but it hogs system resources in its real time protection.
If you can invest , nothing beats Norton.
\"Still waters run deep\"
\"I smile in the dark .......\"
Scorpion is offline
Old 09-01-2005, 02:51 PM   #3 (permalink)
Wel first of all choose a SAFE P2P software!(I use WinMx which i really great).Use a strong firewall like Look'n'Stop.I also use Kaspersky's Anti-Hacker which is a great tool against Hacking attacks.In addition to these use AVAST.This shud tak care of Security Issue.Believe me from the day i hav been using these not a single succesful attack tuk place on me.
Earth is full.Go home.
adorablesrini is offline
