Screenshot is taken by pressin the Print Screen button in keyboard.
Then u open MS Paint or IrfanView or any other Image editor an Paste the image.
Initially,that is while taking screenshot,it's size can not be specified,it will be as large as ur monitor.Then u can use IrfanView to reduce the size or resolution.(In IrfanView,use Edit>Resize/Resample option).
http://swatrant.blogspot.com/
