Old 26-12-2006, 11:40 PM   #1 (permalink)
Default Access denied in one unknown folder-problem
One Folder in my D drive contain some files and one update folder which I cannot open, delete,rename or moved. Now, my problem is I happen to drag my important folder containing movies and pictures within this Folder and I cannot retrieve it back or open it. Using system restore I restore it back but none of the multimedia files could be opened or moved. What could be the problem? Is there any way that I can open the multimedia files again? Please help.
H.Lalnunmawia is offline
Old 27-12-2006, 12:34 AM   #2 (permalink)
Back to School Mr. Bean !
mod-the-pc's Avatar
Default Re: Access denied in one unknown folder-problem
Can you try accessing the folder from command prompt and let us know. How about accessing the folder from Linux (if you have one installed). Do you login as administrator in windows?
Desktop: P4 2.8E, Intel 865GBF, 512MB Hynix PC3200, Samsung SV1204H 120GB, Samsung SW-248F, Creative Inspire 4400, Samsung 793MB, Compro PVR/FM, WinLIRC
Laptop: HP Pavilion dv8210us
mod-the-pc is offline
Old 27-12-2006, 01:07 AM   #3 (permalink)
shashankkosta's Avatar
usually an "Access Denied" folder or the "Folder in use" folders or files can be deleted using the Nero Burning Rom, start a new session in the nero burning rom, in the file browser, select the file or the folder which u want to delete and right click the file/folder in the file browser and delete.
in the same way, try copying the movie files which you had moved, to some other location n then try and play them, i donno if this would work but just give it a try.....
shashankkosta is offline
Old 27-12-2006, 01:18 AM   #4 (permalink)
Thanks guys for lending a helping hand. I just solved my problem through this link http://support.microsoft.com/kb/810881. Hope this would be helpful for others facing the same problem. Yes, Digit rules.
Old 27-12-2006, 09:59 AM   #5 (permalink)
rajaryan_13's Avatar
thnx for the M$ link it solved my problem of deleting file also
rajaryan_13 is offline
