Old 26-12-2006, 09:56 PM   #1 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
Thumbs down phpbb problem..after easymod installation
hi guys...
i am having a phpbb forum in 110mb.com
i tried to install easymod version 3.0 beta...
the installation went half way thru when i realised that my host has safe mode on
which does not easy mod to work ...
ut it was too late as the installation process have replaced my original files into easymod modified ones..
now new users cant register...
it is sending me this error
Warning: fsockopen() [function.fsockopen]: unable to connect to smtp.unlimitedmail.org:0 (Failed to parse address "smtp.unlimitedmail.org") in /www/110mb.com/s/k/o/a/r/_/_/_/skoar/htdocs/phpBB2/includes/smtp.php on line 110
Warning: Cannot modify header information - headers already sent by (output started at /www/110mb.com/s/k/o/a/r/_/_/_/skoar/htdocs/phpBB2/includes/smtp.php:110) in /www/110mb.com/s/k/o/a/r/_/_/_/skoar/htdocs/phpBB2/includes/page_header.php on line 483
Warning: Cannot modify header information - headers already sent by (output started at /www/110mb.com/s/k/o/a/r/_/_/_/skoar/htdocs/phpBB2/includes/smtp.php:110) in /www/110mb.com/s/k/o/a/r/_/_/_/skoar/htdocs/phpBB2/includes/page_header.php on line 485
Warning: Cannot modify header information - headers already sent by (output started at /www/110mb.com/s/k/o/a/r/_/_/_/skoar/htdocs/phpBB2/includes/smtp.php:110) in /www/110mb.com/s/k/o/a/r/_/_/_/skoar/htdocs/phpBB2/includes/page_header.php on line 486
and also this when smtp use is switched on in admin panel
Could not connect to smtp host : 0 : Failed to parse address "smtp.unlimitedmail.org"
DEBUG MODE
Line : 112
File : smtp.php
please guys help me...
i dont know wht to do....
i have switched off smtp use in admin panel...but even though i am having problem...
when i switch off smtp use in admin i get the error for new registration
Failed sending email :: PHP ::
DEBUG MODE
Line : 234
File : emailer.php
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
naveen_reloaded is offline
Old 27-12-2006, 12:16 AM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: phpbb problem..after easymod installation
i am not sure but by any way are u using a theme other than subsilver
http://beingmanan.com
iMav is offline
Old 27-12-2006, 07:11 AM   #3 (permalink)
yes i am using cobalt theme
guys...i just want to know....i have backed up my database....
wht if i put everything again...from the first and restore the database with the backed up one...
will it work???
can anyone help me out...
Know My Thoughts..
Old 27-12-2006, 10:28 AM   #4 (permalink)
iMav's Avatar
easy mod normally does giv error wen using another theme ..... best way install a mod is to manually
as far as this problem goes i hope u hav backed upur files b4 u editted them if not then do the whole thing again
iMav is offline
Old 27-12-2006, 05:33 PM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
well for cobalt theme issue... reffer to their support forum...
http://www.jakob-persson.com/forums/index.php
the person Jakob is a helpful guy... Feel free to ask their... in many case i have obtain help from him while tring to install a Mod which didnt work good on Cobalt Theme
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 27-12-2006, 06:37 PM   #6 (permalink)
thnks guys...
but i cant revert the files...i have lost....my forum...
i had enough...
but can anyone say wht is sql database...
coz i remember entering some sql enteries ...
i have now started a new forum....
i had enough XP ...
one thing i got is backup whtever u do...
thnks guys...please do mention about SQL database....
Know My Thoughts..
Old 28-12-2006, 04:18 PM   #7 (permalink)
saurabh.sauron's Avatar
if u had taken a database backup, u can restore that forum. u should regularly take databse backups. also, i dont recommend easymod as it can corrupt your database if the installation fails or if their is an improperly executed sql query. manual is the way to go, even if it takes more time.
saurabh.sauron is offline
