Old 08-01-2005, 07:57 PM   #1 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default FEDORA CORE 3 & NTFS
Hi im using the FEDORA core 3 from DIGIT.
I have a intel P4 2.8 HT prescott with intel 915 mobo and 80GB Segate SATA HDD
How can i mount NTFS partition in Linux?
i use the following command to mount a FAT32 partition (E: Drive)
mount -t -vfat /dev/sda6 /myfolder
how to mount all the drives at boot up??
how can i connect to internet using dial up in Fedora core3?
Thanks
Charan is offline
Old 08-01-2005, 11:18 PM   #2 (permalink)
busyanuj's Avatar
first, login as root.
next, launch terminal and type this: uname -r
note the kernel version of your Fedora Core 3.
next, go to: NTFS rpms and download the appropriate rpm package for installing the ntfs kernel.
next, in terminal type this command from the folder in which the downloaded rpm is there:
rpm -ivh ****.rpm
to install the ntfs kernel.
note: replace ****.rpm with the exact name of the rpm package.
next, load the kernel by typing:
/sbin/modprobe ntfs
create a folder ntfsdrive in /mnt
mount your ntfs partition by typing:
mount /dev/hda1 /mnt/ntfsdrive -t ntfs -r -o umask=0222
also, go to the folder /etc
edit fstab file and add this line:
/dev/hda1 /mnt/ntfsdrive ntfs ro,umask=0222 0 0
in all this, I assume that hda1 is the partition that you want to mount.
from now on, linux will automatically mount the hda1 partition for you when it loads.
next, you haven't told whether you have internal or external modem.
for external modem:
firstly, launch Terminal and type setup. from there select the System Services option and ensure that the "kudzu" service is enabled. reboot if necessary.
you should know whether the modem is plugged into COM 1 port or COM 2 port.
next, in Gnome,
go to System Settings --> Network and there select the "Hardware" tab.
next click on Edit tab.
here, the modem device should either be /dev/ttyS0 (for COM1) or /dev/ttyS1 (for COM2)
next make the "baud rate" = 115200
and the "Flow Control" should be Hardware (CRTSCTS)
now, create an internet connection, fill-up it's phone number, username, password etc
and then try connecting to internet.
you're in hard luck if you have internal modem, you'll need to download the drivers for internal modem, as most of the internal modems are winModems and they aren't detected by linux.
for internal modems, read GNUrag's post on finding drivers for internal modems.
busyanuj is offline
Old 09-01-2005, 11:54 PM   #3 (permalink)
Salieri Family
hard_rock's Avatar
Location: Somewhere in Internet.......Have dynamic IP address
Also can u tell me how to play mp3 n movies in FC3.(coz Xmms doesn't support mp3)
hard_rock is offline
Old 10-01-2005, 09:54 AM   #4 (permalink)
TO play mp3 download mp3 plugin at
http://ftp.freshrpms.net/pub/freshrp...a/linux/3/xmms
Million's Of Open Minds Can't Be Wrong!
http://nc.xmgfree.com/weblog
Everybody Wants to go to Heaven...But nobody wants to Die! :wink:
naveenchandran is offline
Old 10-01-2005, 08:27 PM   #5 (permalink)
FooBar Guy
GNUrag's Avatar
that's not quite correct. XMMS always supported MP3s.. that's why it was designed for, playing music. Its Fedora that does not support MP3s
http://web.gnuer.org
GNUrag is offline
Old 10-01-2005, 10:52 PM   #6 (permalink)
can fedora core 3 b installed on an NTFS partition? is it a good distro if i wanna learn the basics of linux?
Nemesis is offline
Old 11-01-2005, 03:53 PM   #7 (permalink)
FooBar Guy
GNUrag's Avatar
Why do you love NTFS so much ??? Fedora is an OS, and it needs a separate filesystem... ext3 in this case.
GNUrag is offline
Old 11-01-2005, 11:02 PM   #8 (permalink)
hehe...i guess u misunderstood my question....i have win xp pro installed on my system and i have a single NTFS partition...i wanted 2 know if i can install fedora core 3 on it...like red hat 9 needed fat 32 as it would not begin installation or partition the drive if u had an NTFS partition
Nemesis is offline
Old 11-01-2005, 11:41 PM   #9 (permalink)
busyanuj's Avatar
Nemesis, NT file system doesn't give write permissions to Fedora Core.
you can only read an NTFS partition. Currently, writing to it is not supported.
so, you'll need an ext3 partition.
busyanuj is offline
Old 12-01-2005, 03:14 PM   #10 (permalink)
ahhh ic...thanx anuj....guess ill have 2 use knoppix live cd and wait until either i partition my drive or fedora supports NTFS...
Nemesis is offline
Old 14-01-2005, 03:17 PM   #11 (permalink)
Default Its simple dude...
Get the Mandrake 10 CD from any one of ur friend who has it...
then install the application which lets you mount the NTFS drive at start up....
Well u wanna know the name of the application.... i'll let you know soon!
M sorry if you find my idea idiotic....
I did it this way...
Keep Rocking!!
Varun Nair
thinkdigital is offline
