If i have BSNL DATAONE 900 UL PLUS PLAN With WiFi Modem can i use it simultaneously in both laptop as well as desktop in the same home for seperate internet usage.???i m asking this coz it is a single user license..
single user license...... i think this is tat connection is issued for subscribers having telephones in individual names working at homes/residences used for personal use/purpose.
Suscriber can hav more than one system connected to Dataone network....but stricky for non-business purpose...if failed to do so one can fell in legal trouble
Well if you're going to be so goody goody you can use it with your laptop for a while, and then separately with your desktop for a while. You'll go straight to heaven when you die man.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
Modem is a router as well..
So you can use..
BTW, I got mt841 .. but I think to use it in WiFi mode , it needs some external stuff.. some pcmcia card..
Any luck.. where to get that and wht cost ?
So you can use..
It is usually supplied by BSNL, else you can buy one anywhere
