Old 24-12-2006, 12:27 AM   #1 (permalink)
vipergt's Avatar
Default compress 700mb to 1.44mb
can anybody tell how to compress 700mb file into 1.44mb in rar format without splitting
vipergt is offline
Old 24-12-2006, 12:44 AM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: compress 700mb to 1.44mb
you can only do that by KGB archiver.then you can compress the.kgb file as rar
Arsenal_Gunners is offline
Old 24-12-2006, 01:47 AM   #3 (permalink)
hailgautam's Avatar
We had a long discussion here:
http://www.thinkdigit.com/forum/showthread.php?t=36334
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 27-12-2006, 10:49 AM   #4 (permalink)
Mad and Furious
redhat's Avatar
Thumbs up Re: compress 700mb to 1.44mb
Its almost impossible to achieve that level of compression. Not today, but even in the years to come. Try Winzip 11, or winrar. They will give you a good level of compression. Ummm. Even 7-zip is a good choice, though not popular, it gives better compression that winzip, and also WinRAR(almost!)
redhat is offline
