Old 23-12-2006, 10:27 PM   #1 (permalink)
kool's Avatar
Talking i've **7** question to ask you.. Can u help?
Hi frnds,
I’ve few question to ask you..
1---\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\
My old optical wire mouse was working fine, but last week its “left button” was not working fine so today I bought new mouse. Now I want to know that what I should do with old one. Its 4 year old “ACER” brand. That time I bought it for Rs.1400. I’ve read somewhere that optical mouse can be use as scanner. Is it true? If yes, then please tell me how? Its PS/2 interface.
Reply soon…
2--\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
I’ve win XP SP2 installation file saved on my E: drive, Is it possible to install XP without CD on C drive?? If yes how?
3--\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
I’ve Firefox 2, now my old extensions are not working with this new firefox. How can I make them compatible? And also tell me about some good extension that will help in
(1) Autologin for GMAIL, ORKUT, YAHOO.
(2) Blocking banner, ads, flash file in SANTABANTA.com but not wallpaper.
4--\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
I’ve Opera 9.02, how can I block all ads, banners in santabanta.com? I’ve also ZoneAlarm 6 installed but when I check to block BANNER, SKYSCRAPPER ADS, ANIMATION, POPUP then it also blocks all wallpaper. I don’t want to block JPG image.
5--\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
I’ve too much (more than 200) Offline WebPages are saved on my hard-disk. Most of them are named as index1, index2, content1 and so on… I get confused for searching any specific webpage. Just like we can view image file, pdf as thumbnail, why can’t we view webpage preview as thumbnail?? Is there any software that can preview WEBPAGE file? Or renamed automatically by their contents??
6--\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
Is there any software that can change DVD REGION?? Or any DVD PLAYER that can bypass region setting of any movie DVD?? I’ve lost all 5 chances of my LG DVD rom.
7--\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
I’m dialup user and want to download large files from RAPIDSHARE by the help of download manager by pause/resume function. I’ve flashget but problem is that it doesn’t support pause option in that site.
►► ◄◄ :smile::smile:
kool is offline
Old 23-12-2006, 10:44 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: i've **7** question to ask you.. Can u help?
Ans 1. Dont know,other members will help you.
Ans 2. See Vishal answer 2..
Ans 3. If your old extensions are not working with newer Firefox then you can't make it compatible and install 'Adblock' to block ads from various sites.
Ans 4. Other members will help you in this.
Ans 5. You can't view webpage preview as thumbnail.
Ans 6. Don't know...
Ans 7.If you are a premium member of 'Rapidshare' then you can do pause/resume function in downloading files.
Third Eye is online now
Old 23-12-2006, 10:48 PM   #3 (permalink)
Loading . . . please d'nt
CINTEL ENTRINO's Avatar
LOLzzzzzzzzz.... wat answers
CINTEL ENTRINO is offline
Old 23-12-2006, 10:52 PM   #4 (permalink)
Wise Old Crow
blueshift's Avatar
1. Convert Your Old Optical Mouse CCD into a Scanner !
6. Theres are such softwares but they are not free. DVDIdle Pro
7. You can't resume downloads in RS if you don't have premuim acc as tech_mastermind said.
http://twitter.com/blueshift155
blueshift is offline
Old 23-12-2006, 11:02 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Reply soon…
YES! Boot into DOS using any bootable flaoppy or windows 98 CD and then goto E: drive and then enter into "I386[/b] folder, then give following command:
winnt.exe
It'll start the XP setup
To make the extensions working u can use "nightly" extension.
Alternatively, u can add following line in "prefs.js" file:
user_pref("extensions. checkCompatibility", false);
Indyan can give the answer
Sorry! Don't know.
Don't know whether its LEGAL or not! So can't help atm.
U can't resume from Rapidshare unless u hv Premium account.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 23-12-2006, 11:30 PM   #6 (permalink)
rajaryan_13's Avatar
u can use Slysoft AnyDVD software to make ur DVD region free
rajaryan_13 is offline
Old 23-12-2006, 11:33 PM   #7 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
You've already got answers for 1,2,3 and 7.. So..
4. Opera AdBlock. But lemme warn you, its not such a good solution as AdblockPlus for firefox.
5. Use a desktop search engine like Google Desktop. That will index your files for you!
6. Yes, its legal. Use AnyDVD.
kalpik is offline
