Old 23-12-2006, 07:33 AM   #1 (permalink)
Default What is optical zoom
Hi guys a simple question.
What does optical zoom like 1x,2x represents?
n.regmi is offline
Old 23-12-2006, 08:23 AM   #2 (permalink)
True Techie
nithinks's Avatar
Default Re: What is optical zoom
optical zoom is the actual zoom .. ie it is caused by the actual movement of lenses inside the camera.
http://www.mytechyard.com/
nithinks is offline
Old 23-12-2006, 08:41 AM   #3 (permalink)
krazyfrog
Posts: n/a
An optical zoom in cameras works similar in principle to a telescope. By increasing the distance between the real lens and the zoom lens, the image is made to seem like it has come closer. The number before x is the amount by which the image is zoomed compared to the actual image. So if it is 4x, the image is 4 times zoomed or brought closer compared to the real image.
Old 23-12-2006, 09:32 AM   #4 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
U musta seem cameras in which the lens move forward or retract to original, when the sound of a small motor and other mechanical parts can be heard... yah... that's when optical zooming is done.
There are 2 types of conventional zooming
1. Digital zoom, in which software in camera extrapolate(mathematically guess) the pixels and enlarge the scene. It is same as scaling in image editors like Photoshop. As a result, it is not the original picture, but a "guessed" one and is inferior in quality as it's just scaling, no new pixels added, the same old ones r spread apart!!!
2. Optical zoom, in which the hardware(replace with "lens") are actually aligned to & fro to enlarge the view in the camera. Technically the focal lengths of the lens are varied here. So this gives us as close a picture to the real view as possible and is definitely of better quality. Unlike digital zoom, optical zoom enlarges the subject without sacrificing resolution. It is the true zoom.
The 1x, 2x are the magnifications achieved. It describes the lenses ability to multiply the size of a subject between its minimum and maximum focal lengths. 2x means the picture dimensions are multipiled by 2.
Optical zoom wiki
koolbluez is offline
