Old 23-12-2006, 12:02 AM   #1 (permalink)
Default How to create .gif files
HI! all frnds 0f DIGIT ,frnds i wanted help 4rm u members(at ur wish).
I want 2 know how 2 create ".gif" files, ppl knowing how 2 create plz help me, with NOTES,TIPS,WEBLINKS,TUTORIALS, anything which will teach me create .gif files.
thanks in advance 2 all of u
Waiting for a early reply
I DO WHAT I WANT.. AND THAT'S JUST WHAT DO I MEAN.
sanddy is offline
Old 23-12-2006, 12:04 AM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: How to create .gif files
open any image editor even paint and save the file with extension gif
http://beingmanan.com
iMav is offline
Old 23-12-2006, 12:10 AM   #3 (permalink)
Alive Again...
satyamy's Avatar
ok
wht gif file do is shows 1 image than another than another
n we thinks its a animation, but it not, it only 4-5 images bundled together
for this u need Software called Imageready(Comes with Photoshop)
open Imageready
Now take a New file
Open 3-4 images u want to merge
now drag n drop 1st image to ur new document
in the layers u'll find Layer 1 created
Now at bottom (in the animation palate)
go to (>) button n click new frame
now in layers create new layer n drop ur another image
repeate this for all ur images
Now
1) click on animation palate's 1st frame n in the layers uncheck all the layer (by clicking on the eye at left) only check 1st layer
2) click on animation palate's 2nd frame n in the layers uncheck all the layer (by clicking on the eye at left) only check 2nd layer
3) click on animation palate's 3rd frame n in the layers uncheck all the layer (by clicking on the eye at left) only check 3rd layer
4) click on animation palate's 4th frame n in the layers uncheck all the layer (by clicking on the eye at left) only check 4th layer
(means one animation frame n one layer for each image)
save it as .gif extension
n u have completed
Hope u understand
see my avatar The Great INDIAN Flag
satyamy is offline
Old 23-12-2006, 12:12 AM   #4 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
^^^^^^^^^^^^^^^^^^^^THE easiest one(by MAV3)^^^^^^^^^^^^^^
check if this helps u
http://www.gifworks.com/
wizrulz is offline
Old 23-12-2006, 12:28 AM   #5 (permalink)
Smile Re: How to create .gif files
a heartly thanks to all of u for your valuable help frnd i'm immeditely going to try it, will post when completed
thanks again
sanddy is offline
Old 23-12-2006, 09:59 AM   #6 (permalink)
devgujar's Avatar
Thumbs up Re: How to create .gif files
YOU CAN'T CREATE .gif FILES DIRECTLY
U WILL REQUIRED GIF EDITOR
try this one
http://www.trialware.in/db/design-photo/animation/
devgujar is offline
Old 23-12-2006, 01:07 PM   #7 (permalink)
iMav's Avatar
u missed a very important word .... 'animated' .... u can save any image to gif extension and hav a non-animated gif image
iMav is offline
Old 24-12-2006, 12:57 PM   #8 (permalink)
thanks frnds but my system has broken down so ,i was unable 2 test it it will reply after tsting .
again thanks and plz reply with more purified helps
sanddy is offline
