Old 07-01-2005, 09:09 PM   #1 (permalink)
Default CD COPYRIGHT
is there any free utility that i can copyright my cd so that others can only read but cannot duplicate the cd
CompaqVijay is offline
Old 07-01-2005, 10:00 PM   #2 (permalink)
If it is possible to read the CD that implies it is also possible to duplicate the CD.
But it is possible to implement any kind of protection mechanism to the data in the cd.
Consider Windows XP It is copyrighted! Isn't it possible to make a duplicate?
But still there is a protection mechanism within it! to avoid piracy :roll:
Million's Of Open Minds Can't Be Wrong!
http://nc.xmgfree.com/weblog
Everybody Wants to go to Heaven...But nobody wants to Die! :wink:
naveenchandran is offline
Old 17-01-2005, 12:32 AM   #3 (permalink)
h4ck3r
Posts: n/a
Default Hello mr.naveen and mr.vijay ....
Hello mr.naveen and mr.vijay .... I think there is one std way that is atleast more difficult than the others to crack .. you can code an algo which detects the hdd make and genreates serials based on the company and the serial no of the hdd. the hdd serial no is unique and the serial cant be used more than once .. this is an effective method i think ?? .. Correct me if iam wrong
(I ALSO SAW A POST SOME WHERE FOR CD ENCRYPTION AND RECOMMENDED A SOFTWARE CALLED CRYPTAINER) I think this is better than all protection schmes to protect cds ..
Cheers from
...::th3 h4ck3r ::... 8) 8)
Old 17-01-2005, 02:20 AM   #4 (permalink)
Even if u do get a solution it is bound to get cracked sooner or later.
amitsaudy is offline
Old 17-01-2005, 02:25 AM   #5 (permalink)
SABER RIDER
maverickrohan's Avatar
Hey!
Me has a couple of *** CDs which play only on the VCD player but not on the comp, I tried them in Linux too....But it just says Bad file System.........Anyone knows what do they use to do that............And how to overcome that
In Nero, In the VCD section, Dates Tab, i have seen "Volume Effective & Expiration".....does anyone know what that does..........I was too bored to try out what it does ........anyone knows what it does?
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
maverickrohan is offline
Old 17-01-2005, 07:19 PM   #6 (permalink)
hey rohan
try using software named isobuster. it reads almost any cds even those which cant be copied on to hdd.
there are other software but i havent tried them
snehal_prabhu is offline
Old 17-01-2005, 11:31 PM   #7 (permalink)
SABER RIDER
Hey Thnx Snehal,
I'll try ur trick, but do u know how to create such screwed up stuff...
Old 18-01-2005, 11:13 PM   #8 (permalink)
h4ck3r
Posts: n/a
@ maverickrohan : i think this toopic is about cd copyrights and not about how to retreive data from a incompatible cd..
Sorry for the comment , but you are deviating the topic :roll:
Old 19-01-2005, 04:36 PM   #9 (permalink)
Default Re: CD COPYRIGHT
O frnd,
Try to http://www.cdmediaworld.com/hardware/cdrom
Eventhough,this is for media CD,this may be useful to you.
pathakjr1 is offline
Old 20-01-2005, 01:24 AM   #10 (permalink)
SABER RIDER
@hacker
Dudeh.....in no ways am i deviating from the topic man..........
The CD I was reffering to was'nt an imcompatible CD in the true sense of the word "imcompatible" ............. it was an ordinary CD-R which was burnt in such a way that it played perfectly well on a normal VCD player, but Windows & Linux din't detect it(they just showed the folders n files but u cud'nt read them)..........this happened cos it had a modified File System...........
Nowadays VCD Cos. are using such methods to prevent duplication of CDs on PCs, etc. ............ So if u get it.....I was bang on TARGET....................the CD i was refering to was very close to the CD we want to make in this thread..........and i was asking if there is anyone who knows how to make CDs like that..........
@snehal
Hey thnx dude......ur trick did work..........IsoBuster is really kewl.....one of the resons it can read Cds with modified FSs is cos it does not use the WinASPI but something know as SPTI as an interface
But again....anyone knows how to make these CDs...and anyone discovered what that feature in Nero does............
