which is the best codec to convert movies keeping the size say 500 mb for a movie---best quality at minimum space.and which is the best converter for them
but 500 mb is too less.. u can get movies wid awesome qualities @ 700 mb using Dr.Divx... Also xilisoft is equally gud.. but both of dem r time as well as memory consuming process..
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
What is the Linux(ubuntu) equivalent of Auto Guardian Knot?
I don't know what is auto guardian knot, but in linux I use Avidemux to encode my vob to Xvid. If the DVD is good I rip and encode directly using K3b itself
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
