Hi DeXter
First of all i would like to thank you for sharing your idea of
Security System with us in the Aug 2004.
I found your concept really cool
I am having a few questions regarding the
"IVM software from Swift Sound"
I hope that you will help me out.
PC Configs
P-III 450Mhz , 256MB SDRam , D-Link 56Kbps Data Fax Voice Modem
Mtnl Mumbai Landline Phone no Caller - ID Feature
1.> well when i tried to run the basic .ivr file with the software and simulated the test call it worked fine with the simulation but i could not record the msg in simulation.
2.> when i kept the software running in the default .ivr mode and i called
my landline phone which is connected to my pc i could hear the answering machine software voice thru my pc but not on my cellphone.
and when i tried to say some msg that msg was not also saved on the
pc.
3.> without the caller-id feature enabled thru mtnl can i still get the
incomming users number thru this software or i will have to enable this feature with mtnl.
Please can you help me in configuring the software
I dont require any source code from you but just help me in configuring
the software for answering machine , callerid and ivr setup.
Hoping for a reply from your side
