Old 20-12-2006, 09:23 PM   #1 (permalink)
niku_19jan's Avatar
Default hw to create swf file.
i want to knw which soft shld i use to make flash files.
as many eye catching files r available on net & i also want to make one
so plz guys help me....
niku_19jan is offline
Old 20-12-2006, 10:04 PM   #2 (permalink)
rajaryan_13's Avatar
Default Re: hw to create swf file.
depends on your content, like Macromedia flash is an extensive software but there r lottsa a appli to make .swf files with albeit for different purposes but most of them for making animated logos and banners
rajaryan_13 is offline
Old 21-12-2006, 04:28 PM   #3 (permalink)
niku_19jan's Avatar
ok bro can u tell the soft for making animated banner n logos?
Old 21-12-2006, 08:25 PM   #4 (permalink)
9437077259
go4saket's Avatar
There are huge number of softwares that will help you to make animated banners and logos, depends on which format you choose. If you want it in GIF format, you can go for Adobe Imageready. For SWF format, use Macromedia Flash.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 21-12-2006, 08:28 PM   #5 (permalink)
Tech Geek's Avatar
This may help you
http://www.freedownloadscenter.com/B...if-making.html
Tech Geek is offline
Old 21-12-2006, 11:11 PM   #6 (permalink)
niku_19jan's Avatar
ok bro. wil download the appropiate soft.
Old 21-12-2006, 11:44 PM   #7 (permalink)
harikatt's Avatar
any software can work to get the swf output.., the macromedia flash is the good and best one to develp good animated web graphics..
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
harikatt is offline
