Old 20-12-2006, 03:23 AM   #1 (permalink)
Post my control key is working like a monster.......
Sometimes when I press my ctrl key for 6 second’s or more of my keyboard (I’m using a laptop). The windows started to behave amazingly; tremendously the cursor disappears & starts to open different windows without my permission. It opens volume information box, start up menus (5 or 6) & folders like my pictures & my music too. This act stops after 1 min when my desktop is full of unwanted items & It goes back to its normal behavior after 3 or 4 min.
Can u plzz tell me why this is going to happen with me??? Is this is any effect of spyware or keylogger. I have already installed Norton internet security 2006, Avg and Avast antivirus on my system.
If this is going due to any virus…..plzz help me to destroy it.
sandeep bhatia is offline
Old 20-12-2006, 06:40 AM   #2 (permalink)
nishant_nms's Avatar
Default Re: my control key is working like a monster.......
one question have u installed Norton internet security 2006, Avg and Avast together on ur PC. If so then first uninstall two of them because no one will be working correctly if u have got two or three of them together
nishant_nms is offline
Old 20-12-2006, 09:31 AM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
I dunno about your "Ctrl" problem, but as @Nishant said
Dont put Three AV's at a time. if you want the best security, then install ZoneAlarm (or)Comodo Firewall (free/paid), & a good Anti Virus, like AVG, Active Virus Shield (AVS) [free] (<-Kaspersky based AV)
here's a CNet Review on AVS its rated 7/10 Very Good.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 20-12-2006, 10:19 AM   #4 (permalink)
NikhilVerma's Avatar
There are some Accessibility settings in Windows which get activated when u press some key multiple times or hold them for long .... check that in the control panel...
NikhilVerma is offline
Old 24-12-2006, 03:28 AM   #5 (permalink)
Post Re: my control key is working like a monster.......
thankx 4 ur suggestions......
but don't u guys think that 3 a's give me extra security coz i have readed in sum books that one antivirus is not a complete solution for today time & that's y i have insatalled 3 antiviruses at a time........wat u think??????
Old 24-12-2006, 02:00 PM   #6 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
most prob ur ctrl key works as a 'function key' for extended operations using keyboards.. jusk like buttons on keyboard for play/pause,volume,word,homepage,search,sys info...
they must be getting activated when u press other keys like may be 'p' for play and 'h' for home after u activate that feature with the ctrl key...
my laptop has a similar button but it is labeled 'Fn' for function and then followed by it if i press the appropriate key i can start lots of stuff...
__________
why dint u try ur manufactorers support site for the drivers for ur keyboard..
like mine are called quicklaunch keys from compaq
Last edited by Rollercoaster; 24-12-2006 at 02:00 PM. Reason: Automerged Doublepost
Rollercoaster is offline
Old 25-12-2006, 09:46 AM   #7 (permalink)
rajaryan_13's Avatar
3 av will make your system working unstable, there can be constant shutdown or hangups...just think about all trying to do the same stuff and nobody doing it well but u can put a couple of Firewalls if u wish
rajaryan_13 is offline
