Re: uninstall Client Services For NetWare??
"Client Services for Netware has disabled the Welcome screen and Fast User Switching. To restore these features , you must uninstall Client Services for Netware."
Hey buddy.....
1. Open Control pannel
2. Click To Network Connection
3. A window wil appear
4. Right Click On Icon For Example-
Dail Up Connection
Virtual Private NetWork Connection
5. A menu Will Appear
6. Click On Propertise
7. A dialog Box will Appear...
8. There will be many tabs Ex Genral, Options, Security, Networking.
9. Click On Networking Tab
10. A dialog box will be dispalyed which shows:
THE CONNECTION USES THE FOLLOWING ITEMS
11. Now, As u scoll down it will dsplay all the uses of connection.
12. You willl also see Client services For NetWare which will be checked
13. Uncheck that Box......
14. cLCIK OK
15. restart UR Pc.....
16. DO THE WORK......
OR
Try to uninstall it from Start > Run > appwiz.cpl {Press Enter} (Add-Remove Option)
Note:Novel Client services are used for logging on to a Netware network (the Windows Logon can be used to login to Netware but it offers limited features. With Novell client you can use Novell Printers and Groupwise ).
||uLtiMaTE WinNER||
