Old 07-01-2005, 01:46 PM   #1 (permalink)
Default AVI problem
Hi there
I am trying to convert the VCDs into avi format using virtual dub.
Sexy software isnt it.
Now I am using divX codec.
But the problem remains that the movie that comes in two cds is not converted into such a small size so that it can be stored in one cd.
Can anyone tell me the bitrate of audio and video and the picture size so that the movie can be converted into one cd.
i.e the movie size should be 650-699mb.
tushat_novice
Don\'t assume. It makes an ASS out of U and ME
tushar_novice is offline
Old 07-01-2005, 01:55 PM   #2 (permalink)
NikhilVerma's Avatar
What audio compression codec are you using?
NikhilVerma is offline
Old 07-01-2005, 04:12 PM   #3 (permalink)
MP3 not lame but the simple one.
96-112kbps
Old 07-01-2005, 04:28 PM   #4 (permalink)
swatkat's Avatar
Use Dr.DivX.
http://www.divx.com/divx/drdivx/
http://swatrant.blogspot.com/
swatkat is offline
Old 07-01-2005, 07:40 PM   #5 (permalink)
Ethan_Hunt's Avatar
Use The Xvid Codec.....Its Quite Good.....And For Audio Its Better to Go For The Mpeg Layer 3 Bitrate at 112 or 128Kbps As Its The Video Cd U Wanna Compress Or The Ac3 Compression Was The Best For DVD's 8)
Ethan_Hunt is offline
Old 15-01-2005, 10:03 PM   #6 (permalink)
If u hav WinXp then use Windows Movie Maker.It has got lots of options.Check out if u find something Suitable
Earth is full.Go home.
adorablesrini is offline
