Old 18-12-2006, 04:31 PM   #1 (permalink)
Default Inquiry
Hi kind guys..!
Have pity on me.....!!!
I have been seeking an idea to create a back up cd (A cd from which i can install that earler installed program) from my own computer on which that program earlierly installed. Any of you has idea if you have please give me deatail instruction.
I do not mean to say the os backup cd but cd containig program that is earlierly installed in my computer . and using the cd i can reinstall the program after unstalling it.
__________
anybody there to answer me
Beeanjan is offline
Old 18-12-2006, 05:06 PM   #2 (permalink)
shantanu's Avatar
Default Re: Inquiry
There are many cd creators which help you to make these kinds of back up cd's
(i think you mean bootable with a os)
so here the links .
www.nu2.nu
you can also search as:
www.google.co.in
and write barts way to make a bootable back up cd
shantanu is offline
Old 19-12-2006, 12:43 PM   #3 (permalink)
Default Re: Inquiry
I do not mean to say that types of cd but the cd containig program . I want to creat such type of cd from earlierly installed program and again i want ot install that program after unstalling from my pc . Are u clear?
__________
No body i found an expert in the forum.......?????
I am novice creature , want to learn something from learned ones but i just failed. so again i seek a solution "can we create a cd containing program that is earliearly installed in the pc and from the cd we can install that program again after removing from one's pc."
Beeanjan is offline
Old 19-12-2006, 12:57 PM   #4 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Wink Re: Inquiry
__________
Hey! If u didn't find any solution that doesn't mean that, no one can help u. Here r many experts & they will surely help u but the only prob is that, no one is able to understand what r u asking (as I guess).
I m also unable to understand what do u want to say. Tell clearly.....
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 19-12-2006, 01:32 PM   #5 (permalink)
The Researcher
Default Re: Inquiry
yOU SHOULD HAVE THE PROGRAMME CD'S FROM WHICH YOU INSTALLED THE PROGRAMMES, IN THE FIRST PLACE. IF YOU WANT TO SAY THAT YOU WANT TO CREATE CD'S OF PIRATED SOFTWARE, FORGET IT. NOBODY HERE WILL HELP YOU. IF INTENDED SOMETHING ELSE, BE CLEAR
Ramakrishnan is offline
Old 19-12-2006, 01:57 PM   #6 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Inquiry
When you install a program I do not know of any way to recreate the installer back from your pc. You have to have the original installer file.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
