I have win xp sp2, 512Mb ram, 80GB HD...The problem is after booting up the loading of system tray (right side bottom corner icons) is taking approx 2 mins...I have disabled all item in msconfig...startup.
Thanks in advance.,.,
use a simple freeware tool WINPATROL, to remove or disable unwanted entries from the starup, controlling services, etc, on the fly. keep as less startups as posbl, coz u can always click start them as n ven u need them.
