First you try all the software settings. If that gives no help then you can adjust the focus (i.e. the clarity/sharpness) by opening the monitor's back cover (if you can dare to). There on the PCB there is a seprate section called the EHT which is distinguished by some steel covering. Be very careful as this generates very very high voltage. On the back side of the EHT you can see two setting knobs (to be turned by small phillips head screw driver). One is for focus & other is for brightness. Set it from there. PLEASE LET IT DONE BY A TECHNICIAN IF YOU DON'T KNOW ANYTHING ABOUT IT !!!!!! BE VERY VERY CAREFUL!!!
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
