Old 18-12-2006, 02:41 AM   #1 (permalink)
gxsaurav
Posts: n/a
Default Photoshop CS3 Beta : Review 1
Adobe has recently released Photoshop CS3 beta for Mac & Windows. The beta doesn’t have many feature improvement of CS2, but the notable interface changes are worthwhile checking, they have made life easy
The UI of Photoshop has new icons, & they are no longer using the CS2 “Feather” theme, which is good touch as all Adobe applications are now incorporating a new docked UI, & no longer palates, which was bad anyway
On first look, u will find that Photoshop CS3 is 95% like CS2, adobe bridge is 100% changed, seems like they took lessons from ACDSee. The thumbnails are real time, they update on the fly. The UI of Photoshop & Bridge is really fast now, quite good update.
If you have a file open in Photoshop then u can no longer click on the file’s maximize button to maximize it, u have to click on the “Change screen mode” button found at the lowest part of left side toolbar. I M myself using the 2nd docked interface a lot
New features in this version are a few only right now, such as quick select tool, which is like enhanced magic wand, now u click on many sections & depending on pixel similarity it selects those pixels. Like in one case, on my bike’s pic, it selected black color of fuel tank, but not the highlight glaze created by the sunlight.
Camera RAW is updated to 4.0, well…I don’t use it & have no idea, don’t even have a RAW file based camera here, just a K750i
Still adobe doesn’t have an inbuilt noise reduction tool as effective as Noise Ninza, they should give one, and it’s going to be a boon for those who take Pics from digital cams & mobile cams
Seems like they want to give that functionality to light room, which is like Photoshop for Digi cams
More than the words, u should look at the screenshots. As u can see, on top there are no changes other then the UI, but inside there are a few changes
Photoshop CS2 like Workspace
Photoshop CS3 code name redpill
Docked UI
Adobe bridge
Old 19-12-2006, 12:21 AM   #2 (permalink)
tinku dhar's Avatar
Default Re: Photoshop CS3 Beta : Review 1
thnx
tinku dhar is offline
Old 19-12-2006, 01:01 AM   #3 (permalink)
 Macboy
goobimama's Avatar
I'm gonna get this one tomorrow... Good bye rosetta i say...
I'm like a bird... :)
goobimama is offline
Old 19-12-2006, 01:28 AM   #4 (permalink)
gxsaurav
Posts: n/a
@ goobimama
u can register on Adobe Labs & download a native version for Intel Mac, Photoshop CS3 is now a universal binary
Old 19-12-2006, 01:14 PM   #5 (permalink)
 Macboy
goobimama's Avatar
I know, I know. Just that my internet was kind of screwed for the past few days. I already have an adobe ID...
Old 19-12-2006, 01:56 PM   #6 (permalink)
tinku dhar's Avatar
dawn .... ,
i think we suld wait for the final version when will it be out !!!!!!!!!!!!!!!!!!!!!!!!!!
Old 20-12-2006, 12:48 PM   #7 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
yes wait 4 FINAL version ...... beta`s r crapp ..........
ax3 is offline
Old 21-12-2006, 02:48 PM   #8 (permalink)
gxsaurav
Posts: n/a
Looks like Adobe is all set to use the 2D acceleration lead from Matrox
Just like Adobe Reader 8, Photoshop CS3 also supports 2D GPU acceleration, using DirectX 9c, which means u will need a Geforce 6 or Geforce 7, Radeon X18xx or Geforce 8 series graphics card to use it. This feature might not be available in Windows XP yet, but u can check if it is available or not using
Edit-> preference->performance->"GPU Accleration" section, there should be a checkbox
Now, all the color gamuts, Palates & effects are rendered on screen using the DX9c GPU hardware
Lets see, 2D/3D Acceleration in Adobe Reader8 , check. Video acceleration already there on Premiere Pro 2 & After effect 7, check. Audio acceleration in Adobe audition from a long time, check.
Old 30-12-2006, 02:09 AM   #9 (permalink)
________
hash!!'s Avatar
cs3's a lot faster from what i've read.... waitin waitin waitin...
hoping they dun do massive changes to the interface like what they did to flash after flash5 to flashmx... that wuz ugly...
phenom 9850be,M2N-E,2x2gb OCZ Platinum CL4 Edition,Leadtek 8800GTS320mb,Tagan 600w stonerock,200+320gb hdd,Optiarc20x DVDRW, SBLive! 5.1,PhilipsA2.610
"so long, and thanks for all the fish..."
hash!! is offline
Old 30-12-2006, 09:45 PM   #10 (permalink)
 Macboy
goobimama's Avatar
I'm getting GPU accelation on my mac.
I must say though, the interface is amazing, especially when it comes to managing palettes and such. Good job adobe.
Old 31-12-2006, 01:45 PM   #11 (permalink)
gxsaurav
Posts: n/a
GPU acceleration is available on Windows Vista too, with latest forceware drivers even on my FX 5900XT. Now if only adobe could relese a CAD & CG desigining software.....I wish they buy modo or mudbox
Goobimama, what does it says in Preference->performance? it says here, Dedicated video card FX5900XT,SSE2
Old 01-01-2007, 05:28 PM   #12 (permalink)
Have been using CS3 fromthe day it was launched & its a great improvement in UI, loads faster that CS2, has great improvement inusing adobe bridge & camera raw 4.0 is faster.
It has many new features such as smart filters which help u to be more creativly apply these filters now.
There are new other feature too , its a great try out & worth trying.
ranjan2001 is offline
Old 03-01-2007, 09:33 PM   #13 (permalink)
shashank_digitreader
Posts: n/a
uhhhh, what r the requirements?
Old 03-01-2007, 11:25 PM   #14 (permalink)
1GB ram, XP SP2 minimum required.
