Old 07-01-2005, 12:19 AM   #1 (permalink)
Default HELP!!
hello friends,
I have an XML file and I want to modify to let the user to modify XML file through HTML forms. I want the code in such a way that i Could modify each recordset individually.
I am looking for some site or some information on how I could so this.
Thank you.
gogaak is offline
Old 07-01-2005, 01:47 AM   #2 (permalink)
welcome to da forum gogaak
i suppose, if u posted ur query in the SOFTWARE DISCUSSION forum, u cud get some reply.
futuristically_ancient is offline
Old 07-01-2005, 06:14 AM   #3 (permalink)
There is a method called ReadWriteXmlDocument() in the .Net under System.Data ( i'm not sure ) may be System.Data.Xml
you better try the following URL:-
http://www.developersdex.com/gurus/articles/592.asp
And if it works pls reply me by posting here.
elumalai is offline
Old 08-01-2005, 11:31 PM   #4 (permalink)
CCIE# 20863
try 2 search on MSDN. Maybe it'll help.
http://msdn.microsoft.com
Bugs can neither be created nor be removed from software by a developer. They can only be converted from one form to another. The total number of bugs in the software always remain constant.
theKonqueror is offline
