Old 06-01-2005, 11:21 PM   #1 (permalink)
harmax's Avatar
Default ADVICE ME
am a big zero in web design or anything to put up a web page.
i want to learn it , basically i want to put up a web page on the web , i need not be stunning and all , but my point is to design a basic stuff,
i know lill bit html . and nothing else
----------------------------now that u know about my knowledge tell me whether i should go on with direct html coding or use any automated tools?
thanks in advance
harmax is offline
Old 06-01-2005, 11:42 PM   #2 (permalink)
cool_dude_prav's Avatar
Default y not...
y not try frontpage or dreamweaver dude...
they're kina cool 8) ... (Like me... 8) )
The Bloglines of an Angry Indian -
www.angry-indian.com
If only life were as easy as Ctrl+Z (undo) and F4/Ctrl+Y (redo)...
cool_dude_prav is offline
Old 06-01-2005, 11:48 PM   #3 (permalink)
Hi harmax,
I too had a similar problem when I started with web page designing.
But, a friend of mine (who makes pro sites) told me to start with actual coding & not to use web authoring tools in the beginning.
My advice would be to start from the basics ( coding) & gradually, to switch over to more advanced tools. But, if you just want to make sites fast, start with dreamweaver or frontpage although it will not give you the satisfaction that you have designed a page the "geek" way.
Best of luck for your future ventures, anyway.
Intel P4 2.6 GHz HT + Intel D865GBF mobo
512 MB DDR 400 MHz RAM
80 GB SATA HDD
128 MB XFX GeForce FX 5700 LE
tejesh is offline
Old 07-01-2005, 12:07 AM   #4 (permalink)
ok guys
NOW can i ask him to google for it ??
:roll:
http://www.davesite.com/webstation/html/
http://www.w3schools.com/html/
http://www.htmlcodetutorial.com/
http://archive.ncsa.uiuc.edu/General...PrimerAll.html
No Mercy, No Limits.
theraven is offline
Old 07-01-2005, 12:00 PM   #5 (permalink)
tuxfan's Avatar
Get hold of a HTML book, like learn HTML in 24 hours. It costs somewhere around Rs. 125. It teaches you all basics and you will be easily be able to pick up things.
Then get a HTML editor like 1st page 2000 (http://www.evrsoft.com) that is free and also contains some ready made javascripts.
After you are comfortable with basic HTML (which you should be within a week with that book in hand) go to http://www.javascript.com and pick up some free javascripts which you can just copy+paste in your pages
tuxfan is offline
Old 07-01-2005, 05:24 PM   #6 (permalink)
U can use trail version of Macromedia Dreamweaver MX if you don,t want to spend on expensive packages.
U can use DHTML scripts from www.dynamicdrive.com and you can download website templates for free from http://www.free-templates-layouts.com/
Lovedeep Wadhwa
cheetah is offline
Old 07-01-2005, 06:16 PM   #7 (permalink)
whoopy_whale's Avatar
Originally Posted by Indyan
The easiest tool for making webpages by far is WEB PAGE MAKER
Forget about Fontpage
get it frm
URL http://www.webpage-maker.net/
That's true...Webpagemaker is really good and easy to use.They provide some good templates too.If you don't even know the basics of HTML,it's better to forget about dreamweaver and all for the time being.But try to learn the code.
Virtual Mechanics Sitespinner is also a good one...
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 07-01-2005, 07:43 PM   #8 (permalink)
I wouldnt make my life difficult doing full HTML programing ; prtfer using Dreamweaver maybe sometimes frontpage
bravefart is offline
Old 08-01-2005, 08:53 AM   #9 (permalink)
i agree. no point learning html hard code. i learnt it and i never use it . in fact ive forgotten it. if you play around enough with frontpage and dreamweaver you ll master it.
check out this sitehttp://www.killersites.com/
they in fact advice to just get a few templates and alter em here and there and load,cause a lot of designs have become common and even if you design something very very innovative someone will soon have their hands on it!
lamrinnirmal is offline
Old 08-01-2005, 10:57 AM   #10 (permalink)
hmm... i personally think the best website designer is Dreamweaver, download it or find it somewhere in digit cds, if they still do this kind of techie stuff, and hey everything is free bcuz u crack it
I learned HTML using this book:
Mastering HTML, Premium Edition,
Authors: Ray & Ray,
BPB publications.
It starts from a hello world kinda code and builds upto pretty neat webpages and even takes u into DHTML,
but if you wanna save time dude, i say u go for dreamweaver. the latest version is completely kickass!
and wats with this "i dont wanna make it look snazzy?" use dreamweaver, do a ltitle cut n paste from various java scripts and u wud b done with a pretty neat looking webpage!!
post here if you need ne help with dreamweaver!!
geek_god is offline
Old 08-01-2005, 06:28 PM   #11 (permalink)
Default Use Dreamweaver And Frontpage
I am also new to web designing , but i am making two websites.
I am using dreamweaver and frontpage .
They are quite easy to use.
U can use flash buttons etc. from dreamweaver and do coding in frontpage ( easier to handle).
Gudluck
Ashish is offline
Old 10-01-2005, 12:50 AM   #12 (permalink)
Default i want to make a dynamic coonected with database.
Originally Posted by tejesh
Hi harmax,
ravishankar is offline
Old 10-01-2005, 01:34 AM   #13 (permalink)
Harmax if u need ne tuts on HTML, JavaScript, ASP, PHP, MYSQL and stuff like that PM me.
Wel i know u r new @ HTML but remember it is just ABC. U cud learn it in a week. So go for coding!!!
Best of luck
PM me if u require gud tuts!
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 10-01-2005, 07:48 AM   #14 (permalink)
Default Well,
Do you want to be a serious designer or just want to learn it as a hobby or to kill your time?
If later is the case, nothing beats the humble notepad and a textbook combo. Get yourself a good book and start with changing colors and headings, then move on to javascripts.
Dreamweaver and fronpage for a pro look and are NOT for a learning enthusiast.
\"Still waters run deep\"
\"I smile in the dark .......\"
Scorpion is offline
Old 10-01-2005, 07:49 AM   #15 (permalink)
Harmax HTML is the basic web design language,,,u said u know a bit of it...there is nothing more in that...it's very simple the things u have 2 do is just have determination and some time you can learn every language easily try this link i advice u that fisrt get perfection in HTML and then u get CONFIDENCE then u can go for JAVA SCRIPTING...XYZ...
U can starting frm the above link.
ALL THE BEST
U CAN\'T STOP WIZARDS
wizard_with_a_wand is offline
Old 10-01-2005, 12:57 PM   #16 (permalink)
harmax's Avatar
thanks to everyone for ur sincere thoughts
harmax is offline
