Re: Edit swf file possible
import the swf into flash... you'l get a frame-by-frame import of the contents of the swf... ie, you'l get an all keyframe breakup of the swf...
basically, you'l get all thats in that swf file, but you'l hvta break it up and find what you wanted from it...
and @ techmastro, dude, i dun think its possible to get the original fla... wont help importing it as well... i've worked a bit on flash... a lil more than basics, so i guess i know what im talkin about... tho i've heard from some random people that there is some s/w that'l help convert the swf into the original fla... but i dun think thats possible... its like exporting a jpg frm photoshop and wishin u could get back all the layers and the psd format like the original psd file... not happening i pretty much think...
phenom 9850be,M2N-E,2x2gb OCZ Platinum CL4 Edition,Leadtek 8800GTS320mb,Tagan 600w stonerock,200+320gb hdd,Optiarc20x DVDRW, SBLive! 5.1,PhilipsA2.610
"so long, and thanks for all the fish..."
