Old 17-12-2006, 08:57 AM   #1 (permalink)
pritish_kul2's Avatar
Unhappy help!!-urgebt
I have a Sony Cybershot DSC - W30 digital camera. If i connect it to the computer then if i want to see the video of mine on my computer. for e g - if i connect it to the computer , then start the camera and then which software should i get to see my picture on the computer.
pritish_kul2 is offline
Old 17-12-2006, 09:31 AM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: help!!-urgebt
"Google's Picasa2" has an option of "Import Pictures" ->select the Device & run it.
btw doesn't the Camera show up as a "Drive" in "My Computer", if it does, then copy the contents of "DCIM" folder.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 18-12-2006, 04:27 PM   #3 (permalink)
i don't want to copy but want to see a video of myself on the computer as we do it on the camera.
Old 18-12-2006, 05:46 PM   #4 (permalink)
a_g = JPKN
s18000rpm's Avatar
ok, then does the Auto-Run window pop up, when you connect the Camera???
(i'm assuming that the Camera is shown as a Drive in "My Computer" window)
If it does, then select Windows Media Player, (or other player of your choice) & press OK.
WMP will scan the Memory Stick & show the Video. now play & enjoy.
or, just open the DCIM folder (in camera), select the video & double click to play.
If you are provided with a Sony s/w (with camera), dont install it. its a complete waste.
I've Sony DSC P41 digital camera (bought frm USA), it came with a s/w CD, & that Sony s/w was a complete bullsh1t. the transfer/file viewing was darn slow .
Old 25-12-2006, 09:18 AM   #5 (permalink)
no, yaar. u didn't understna my problem. i wnat to use my computer as a mirror by connecting the camera. it came in digit also.
Old 25-12-2006, 09:31 AM   #6 (permalink)
Still Shining!
Lucky_star's Avatar
Do u want to use ur camera as a webcam?
Nokia N86 8MP
Lucky_star is offline
Old 25-12-2006, 02:01 PM   #7 (permalink)
ya
__________
ya, exactly
__________
ya. i want to use it as a webcam
Last edited by pritish_kul2; 25-12-2006 at 02:01 PM. Reason: Automerged Doublepost
Old 25-12-2006, 02:10 PM   #8 (permalink)
Livin' in the ghetto
AshishSharma's Avatar
Not sure if it will but check this link and view the tutorial for "How to use a digital still camera as a webcam"
http://esupport.sony.com/perl/model-....pl?mdl=DSCS60
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
AshishSharma is offline
Old 26-12-2006, 06:31 AM   #9 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
@Ashish-Isn't that for the DSC-S60? His is W30.
@Pritish-I suggest that you take a look at this link
I would first suggest that you go through the manual and see if your camera really has the feature of using it as a web cam. If not, I don't think you can use it like one. In case it does, please post your problem here and we'll see what how we can help you.
P.S-Don't forget Google
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
