Old 16-12-2006, 09:18 PM   #1 (permalink)
jatt's Avatar
Question sugestions please
i have celeron 1.2 RAM128 intel810 chipset i want to copy from my
HC46 hanycam to pc but there is no quality when i rendered the movie in
ulead software please please please help what shouldi have to do
i dont want to upgrade my pc i can only purchase more RAM can more ram will solve my problem any idea please i want to get only one thing to purchase only RAM or firewire,can only firewire will solve problem i have checkd on my freinds pc AMD2500 the quality is same so that i think there is no need to upgrade my pc please give me right option
i will be very very very thankful to you friends please hurry.....
jatt is offline
Old 16-12-2006, 09:27 PM   #2 (permalink)
hailgautam's Avatar
Default Re: sugestions please
well, when you edit the movie in any software and save it, the quality gets degraded, as it gets compressed. you will not get the same quality as in the original raw file that you had uploaded to the computer.
plus the quality on a hadycam is not comparable to what you see on the tv, i.e.broadcast quality, they use much better equipment, what you record on a handy cam are something like 320x240 size video.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 17-12-2006, 08:14 AM   #3 (permalink)
jatt's Avatar
thanx but my question is still
jatt is offline
Old 17-12-2006, 08:27 AM   #4 (permalink)
The pWnster
Vyasram's Avatar
no, upgrading ram gives you faster results, but not better results
if ur compressing, use codecs like divx or vp7, btw are ur uncompresses videos of good quality?
Sigs suck
Vyasram is offline
Old 18-12-2006, 08:25 AM   #5 (permalink)
Kiran.dks's Avatar
128MB RAM is just not good enough for Video encoding & related stuff. You need to upgrade the RAM to alteast 512MB. FireWire is also a good option for fast transfer. Since you wanna purchase anyone, I recommend you to go for more RAM. USB is good enough for video transfer.
Regarding Video quality, it all depends upon the encoding quality and Size. Make sure you apply right settings. Never try to compare the video shown on Cam with that of video on PC. It will vary. Contrast and colour saturation will definetly differ.
Kiran Kumar R
Kiran.dks is offline
Old 18-12-2006, 08:40 AM   #6 (permalink)
jatt's Avatar
thanks friends, i think kiran_tech_mania is right so please kiran can u tell me the cost of more RAM128 please i will try both(ram and firewall)if my budget
allows thanks in advance
jatt is offline
Old 18-12-2006, 08:54 AM   #7 (permalink)
Kiran.dks's Avatar
A 128MB Kingston 400MHz RAM costs you around Rs.1200.00.
Kiran Kumar R
Old 18-12-2006, 12:55 PM   #8 (permalink)
jatt's Avatar
thanx kiran_tech_mania i will try and will post results here but can i have to purchase more RAM 256 becasue in future if to upgrade i will then fill next slot with more 256 is it right plz suggest
jatt is offline
Old 18-12-2006, 02:57 PM   #9 (permalink)
Kiran.dks's Avatar
A total of 512 RAM is recommended for Video encoding. If you are tight on your budget, have a 128MB now...so you will be havin 256MB, which is enough time being. Anytime you can expand to 512MB.
Kiran Kumar R
Old 19-12-2006, 04:58 AM   #10 (permalink)
jatt's Avatar
ok thanks but one more question please can i able to purchase capture card instead of firewire if i want or these are differ i think with capture card i can also capture from TV etc. but not with firewire thanks in advance
jatt is offline
Old 19-12-2006, 07:34 AM   #11 (permalink)
Kiran.dks's Avatar
Firewire is better and cheaper solution than purchasing a capture card that has analog RCA and S-Video inputs. So for handycam video transfer Firewire will do. Now it is left to you whether to go for expensive Capture card depending upon your need of T.V video capturing. I suggest you stick to Firewire and upgrading your PC RAM first. Moreover Capture card also needs more RAM to perform well.
Kiran Kumar R
Old 20-12-2006, 08:48 AM   #12 (permalink)
jatt's Avatar
thankx very much i have purchased RAM 128 it works well but i m also trying for firewall for better quality thankx very much friends special for kiran_tech_mania
jatt is offline
Old 20-12-2006, 08:54 AM   #13 (permalink)
Kiran.dks's Avatar
Nice to hear that your issue is solved.
Kiran Kumar R
