Old 06-01-2005, 05:28 PM   #1 (permalink)
mekalodu
iinfi's Avatar
Default append (NODE **q, int num) .... HELP
in data structures using C ...
while adding a node @ the end of a link list
e.g
what does **q stand for ???
*q is the "address pointer" of the parameter passed ....
but what is **q
mekalodu
iinfi is offline
Old 06-01-2005, 05:34 PM   #2 (permalink)
CCIE# 20863
**q stands for a pointor to a pointor.
i.e.
int i *p, **q;
p = &i;
q = &p;
Hope this will clear ur concept. Or Try 'Let Us C' from Kanetkar.
Bugs can neither be created nor be removed from software by a developer. They can only be converted from one form to another. The total number of bugs in the software always remain constant.
theKonqueror is offline
Old 06-01-2005, 09:50 PM   #3 (permalink)
mekalodu
iinfi's Avatar
Default Thanks a lot
Thanks a lot for ur help
if i want to display the "memory address" of a variable or pointer then whats the command in C?
is it
printf("%s",&p)
its not working but...
mekalodu
iinfi is offline
Old 07-01-2005, 03:58 PM   #4 (permalink)
firstly boy, to print a string use "%p"
now try out this code:
    char *s="hi";
    char *p="cu";
    printf("%p",&s);
    printf("%p",&p);
lamrinnirmal is offline
Old 07-01-2005, 04:56 PM   #5 (permalink)
mekalodu
iinfi's Avatar
Thanks A Lot For Ur Help
mekalodu
iinfi is offline
Old 07-01-2005, 07:58 PM   #6 (permalink)
sorry it is not to print a string it is to print a pointer
to print a pointer use the format string : "%p"
