Old 15-12-2006, 11:56 PM   #1 (permalink)
g_goyal2000's Avatar
Exclamation Will 2003 run for 2002?
Will Visual Studio .NET (2002) be able to access MSDN Library for Visual Studio .NET 2003?
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 16-12-2006, 01:10 AM   #2 (permalink)
shantanu's Avatar
Default Re: Will 2003 run for 2002?
IF you are using a original software then you can first update your .net 2002 and then it can access MSDN library .net 2003
shantanu is offline
Old 26-12-2006, 11:25 PM   #3 (permalink)
U mean to say that I first install version 2002 & it will give me an option to update or upgrade?
