Old 15-12-2006, 11:38 AM   #1 (permalink)
The Devil
blackpearl's Avatar
Arrow Properties Plus : Advanced properties
Properties Plus is an Explorer shell extension that lets you modify file attributes, file extensions and time stamps by simply right-clicking. Properties Plus adds a new menu item to the context menu that appears when you right click on a file. You can select a single file, multiple files, or select files contained within folders. You can then easily modify the file attributes, file extensions and the time and date stamps of those files.
This small utility comes very helpful when you want to change the extension of any file. Instead of the usual long process of going to tools>folder options and then allowing "Show extensions of known files" etc, you can just right click and choose "Properties Plus" and then change the extension to whatever you want. Also helpful to quickly hide any file by disguising it.
Context menu and Main window
Download
http://mikrocomputertechnik.fh-mannh...5/pplus165.exe
blackpearl is offline
Old 15-12-2006, 12:17 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Properties Plus : Advanced properties
Thanks
Tech Geek is offline
Old 15-12-2006, 04:07 PM   #3 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Thank You
techtronic is offline
Old 16-09-2007, 06:55 PM   #4 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Unable To Download
||uLtiMaTE WinNER||
Ron is offline
Old 17-09-2007, 04:42 PM   #5 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Even rapidshare link says file not found. Please correct the link.
Here is the correct link: http://mikrocomputertechnik.fh-mannh...5/pplus165.exe
navjotjsingh is offline
Old 18-09-2007, 05:13 PM   #6 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
thnks
||uLtiMaTE WinNER||
Ron is offline
Old 18-09-2007, 05:25 PM   #7 (permalink)
The Frozen Nova
casanova's Avatar
Thanks for sharing.
www.nerdweed.blogspot.com
casanova is offline
Old 20-09-2007, 02:45 AM   #8 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
It says cant run 16 bit windows program.
Quiz_Master is offline
- by Krow
