Old 15-12-2006, 10:40 AM   #1 (permalink)
Default How to get all Dos Commands
hello Everyone!
Friends as i know there are many commands in DOS but many are not working in my window. like - fixboot, fixmbr, fdisk etc.
my question is -
How could i get complete package of DOS Commands for window XP. Everysingle command i want to use, so pls tell me the source.
thanks
sainit is offline
Old 15-12-2006, 10:48 AM   #2 (permalink)
ashisharya's Avatar
Default Re: How to get all Dos Commands
go to command prompt, type help
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
ashisharya is offline
Old 15-12-2006, 11:06 AM   #3 (permalink)
when i print help on command prompt it show many commands but not all.
There are many many other commands in DOS which does not appear by running help command.
So tell me is there any source like microsoft.com or any site where complete package of all commands available.
Thanks
sainit is offline
Old 15-12-2006, 11:42 AM   #4 (permalink)
desertwind's Avatar
I'd suggest you to go here
If you're not able to get it
http://www.computerhope.com/overview.htm
http://www.computerhope.com/msdos.htm
http://en.wikipedia.org/wiki/List_of_DOS_commands
http://en.wikibooks.org/wiki/Guide_to_Windows_commands
http://www.microsoft.com/resources/d...us/ntcmds.mspx
http://www.microsoft.com/technet/arc....mspx?mfr=true
All these I got with a simple google search with key words "dos command list"
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 15-12-2006, 04:38 PM   #5 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Just to clarify a semantic issue.
Fixmbr , fixboot etc are not DOS commands. These are 32 bit programs for Command Line usage. Dos was a 16 Bit operating system which is long gone ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 15-12-2006, 04:40 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
And Fixmbr and Fixboot dont work on XP, only on a boot disk. Also, fdisk doesnt exist for NTFS'd XP either...
Harsh J
www.harshj.com
QwertyManiac is offline
- by Krow
