Old 14-12-2006, 09:41 PM   #1 (permalink)
anilmail17's Avatar
Default Disk checking
whenever i start my PC the disk checking starts and i have completed it several times but it still appears again and again. I also turn off my computer properly. how can i solve this problem or is there any prob with my harddisk
anilmail17 is offline
Old 14-12-2006, 10:37 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Disk checking
Try this:
Open regedit and goto:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager
In right-side pane, change the value of BootExecute to:
autocheck autochk *
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 15-12-2006, 11:27 PM   #3 (permalink)
anilmail17's Avatar
drive c:\
Filesystem:FAT32
No UPS
Old 16-12-2006, 02:12 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
c if this helps :
let it run once completely.
then try this :
run regedit
Edit: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager
Change the BootExecute entry from:
autocheck autochk * /.........
To:
autocheck autochk *
or else try this :
Start> Run> bring up a command prompt by typing in "CMD" and type " fsutil dirty query g: ". This queries the drive, and more than likely it will tell you that it is dirty. Next, type "CHKNTFS /X G:". The X tells Windows to NOT check that particular drive (G) on the next reboot. At this time, manually reboot your computer, it should not do a Chkdsk and take you directly to Windows.
Once Windows has fully loaded, bring up another CMD prompt and type and now you want to do a Chkdsk manually by typing "Chkdsk /f /r g:". This should take you through 5 stages of the scan and will unset that dirty bit. Finally, type "fsutil dirty query g:" and Windows will confirm that the dirty bit is not set on that drive.
Disk check
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 18-12-2006, 12:18 PM   #5 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
solved my problem 2 ..........
thanx 2 all ..........
ax3 is offline
- by Krow
