Well ATI also make graphics cards using their chip like other manufacturer and are marked as BBA (Built-By-ATI) but these are hard to find in India.
These are only available in Canada and few other countries. As far as the comparison b/w the manufacturers is concerned, i think i depends to some extent ... not that greate a difference.
It is what you are looking for. If you r an overclocker you are better off buying an ASUS or Gainward.
If price matters to you then go for Inno3D or XFX.
It mainly depends on the quality of other components (capacitors, RAM chips, etc) which realy make sense if you want to stress them (overclock them).
Performance wise there is not much of a difference if they follow the reference designs by NVIDIA and ATI which they do by all means today.
AMD Athlon64 2800+, MSI K8N Neo3(NForce4), 1GB Kingston DDR400, MSI Geforce 7600GT PCIe, Viewsonic VA702b 17" LCD, Creative SB Live! 5.1, Logitech Z-5300 5.1 THX Speakers, Seagate 200GB SATA HDD
