Old 14-12-2006, 01:07 AM   #1 (permalink)
vipergt's Avatar
Default request
Did any body knows how to compress whole windows longhorn(700mb+) into a floppy size(1.44mb)
vipergt is offline
Old 14-12-2006, 01:12 AM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: request
Its not possible, otherwise MS would provide it for downloading instead of those BIG 2-3 GB ISO images
For more information see following threads:
Windowws Vista 1.4 MB (can that be true!)
Windows Vista full OS latest release RC1 just 1.6MB
Vista in 1.4 MB
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 14-12-2006, 01:28 AM   #3 (permalink)
SE><IE
Posts: n/a
Default Re: request
Lemme give you a brief summary:
  1. It is scam
  2. Compressing 5000 copies of same file wont make the zip file 5000 times in size.
Old 14-12-2006, 01:53 AM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: request
well i heared that KGB archiver can do it... but compressing it with a very very power full system would take days even weeks... same as with decopressing... cant say how true it is as my self havent tried it... but in either case its point less...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 14-12-2006, 04:15 PM   #5 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: request
i dont thing so ....... this compression is possible ...........
ax3 is offline
Old 14-12-2006, 05:55 PM   #6 (permalink)
busyanuj's Avatar
Default Re: request
you mean to say taht the above archiver can actually compress 3 gigs of data into 1.44mb?
would you be kind enough to give us all an insight into the compression algorithm used?
busyanuj is offline
Old 14-12-2006, 07:13 PM   #7 (permalink)
Beware of the innocent
ilugd's Avatar
Default Re: request
theoretically given infinite time and resources, we can compress any amount of data to around 1mb.
Say you compress 1 gb to 700 mb. then again find common patterns with smaller block size and compress to 600 mb. Rinse and repeat.
But as for it being practical (and the technology available commercially), i am not so sure.
Life is too short. Have fun.
ilugd is offline
Old 14-12-2006, 07:19 PM   #8 (permalink)
"Technologic"
Apollo's Avatar
Default Re: request
It's not practical.
Otherwise, there wouldn't have been such advancements in optical disc formats, thereby swelling the capacity of data that could be accomodated on them.
One great use of words is to hide our thoughts.
Apollo is offline
Old 14-12-2006, 07:28 PM   #9 (permalink)
Console Junkie
aditya.shevade's Avatar
Default Re: request
Even if it was possible and practically feasible.... do you have a 1.44MB floppy drive that still works???
Aditya
--- Console Junkie
aditya.shevade is offline
- by Krow
