Originally Posted by EagerBeaver
OK. Thanks. The NFO Viewer is coo
Also I hav another qs. Can I removes these 0 b files ????? There is lots of them on my pc some in program folders some in windows folders...................
No, not all can be deleted.
Simply because some of them are dynamically resizing files that may seems to be 0byte but at other time may be allocated some bytes.
Well windows XP protection mechanism is good enuf that even if u delete some important system file then it will be replaced from system cache.
