Old 10-12-2006, 03:57 PM   #1 (permalink)
Default updating BIOS>.................
hi every1
i wanted to update my BIOS from the update given on the mobo's websit.. but its in ROM format.. so what should i do to install the update.. its a major update therefore i need it to be done.. waitn 4 ur answers.. cya
http://www.mercury-pc.com/downloads_...?productid=507 - file which i hav 2 download
Last edited by beanstalk_230; 10-12-2006 at 03:57 PM. Reason: Automerged Doublepost
beanstalk_230 is offline
Old 10-12-2006, 04:43 PM   #2 (permalink)
anilmail17's Avatar
Default Re: updating BIOS>.................
Put that file in a fresh floppy disk then insert it FDD now restart ur PC and press keep pressing DEL or F1(BIOS key) now look for Flash BIOS option and then BIOS will do the remaing task for u. Remember Improper flashing of BIOS may cause ur MotherBoard to be damaged so do this on ur own risk or look for some official tool for BIOS flasing from Mercury
anilmail17 is offline
Old 10-12-2006, 04:53 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
All BIOS updates come in ROM format, just look into the mobo CD and u should get a utility to update ur BIOS.
Just run the utility and tell the path of the d/l ed ROM file
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 10-12-2006, 05:13 PM   #4 (permalink)
Red face Re: updating BIOS>.................
i hav lost my cd dude.. its mercury mobo.. so cud u plzz suggest ne such software....
- by Krow
