Old 09-12-2006, 07:05 PM   #1 (permalink)
Default No multisession
Got a Sony DVD writer and supportive Nero express and Nero 6 writing software.But when i want to add something in a multisession disk it shows no previous contents and before writing gives the messege that the previous contents can't be seen if i write this session.Before it was doing ok.Plz help.
ra_sriniketan is offline
Old 09-12-2006, 08:14 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: No multisession
If you are able to see the previous content in the menu of Nero while multi session burning, then you can proceed with the writing. Else don't do the writing. You may lose entire previous data.
Kiran Kumar R
Kiran.dks is offline
Old 09-12-2006, 08:20 PM   #3 (permalink)
Tech Geek's Avatar
Did you make the CD a multisession one when you were writing it the last time?
Tech Geek is offline
Old 09-12-2006, 08:24 PM   #4 (permalink)
Still Shining!
Lucky_star's Avatar
Try importing the old contents in to the compilation you want to write now
Nokia N86 8MP
Lucky_star is offline
Old 09-12-2006, 08:24 PM   #5 (permalink)
TheSaint
NucleusKore's Avatar
If you write first with nero burining rom and then with nero express or vice versa you will face this problem
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 10-12-2006, 10:09 PM   #6 (permalink)
Nothing works even the same versions giving the same problem.
Old 29-12-2006, 04:34 PM   #7 (permalink)
s,b+..u cn..
nikhil ramteke's Avatar
if u wish to watch the previously written data then can be watched with isobuster,it is not lost at all,just use this,there r sessions shown of the count equal to written times of the disk,open the session u want and work with it, i can suggest this much only,cant say what is the reason behind ur happenings..bye ,take care!!!!!!!!!
nikhil ramteke is offline
Old 29-12-2006, 07:32 PM   #8 (permalink)
TheSaint
I second this post. However first launch IsoBuster and THEN insert the cd and not the other way round
- by Krow
