Old 04-01-2005, 06:57 PM   #1 (permalink)
Default WebCam Problem
After installing necessary drivers and Logitech QuickCam software when i click on Logitech QuickCam software to start it ....following message appears on screen Video Sorce ...Select a Video Device.......with a Dropdown Menu which has Logitech QuickCam Express to select.....OS is Win98se
vishal is offline
Old 04-01-2005, 09:04 PM   #2 (permalink)
first of all ur post is not at all clear...iam not able to get what exactly is the problem...nyway general help...>>>
remove all the softwarez/drivers nd unplug ur cam...
restart the pc nd install the software WITHOUT plugging in the cam
after installation of software nd drivers is complete restart the pc
now connect the cam,XP will auto detect as it will be USB,install the necessary drivers nd hopefully it will work!!
grinning_devil is offline
Old 05-01-2005, 12:39 AM   #3 (permalink)
swatkat's Avatar
Default Re: WebCam Problem
Yes,what happens after u select ur Cam model and ur OS?
http://swatrant.blogspot.com/
swatkat is offline
Old 05-01-2005, 06:04 PM   #4 (permalink)
After selecting the Cam model when I click OK the same window appears 2 -3 times....after that Logitech QuickCam Express starts which display No WebCam
vishal is offline
Old 05-01-2005, 07:49 PM   #5 (permalink)
doa a fresh installations of drivers/software....as told to u earlier...!
Old 06-01-2005, 09:59 AM   #6 (permalink)
Still the same problem continues No WebCam or in Use
vishal is offline
Old 06-01-2005, 10:27 AM   #7 (permalink)
swatkat's Avatar
Enable USB in the BIOS.
if u have already enabled it in BIOS,then check ur cam and drivers by installing it in another computer,if it does not work there also,try updating the Software provided with cam.
swatkat is offline
Old 06-01-2005, 12:28 PM   #8 (permalink)
USB is eneabled in the BIOS.
Webcam is working properly in another computer...USB printer is also working
vishal is offline
- by Krow
