08-12-2006, 03:54 PM
To view folder option.
 HI...
I have a hp p4 ,and 504 mb of ram with xp , sp2 installed .i want to hide some folder but i can't see the folder option on fallowing the path
start>mydocuments>tools.......... .here i should get the folder option,but i cannot, please help me so that i can hide my unnecessary file.
08-12-2006, 04:59 PM
Livin' in the ghetto
Re: To view folder option.
Looks like ur computer has been hit by the rontrokbro virus check this post for solution already posted in the forum :
Folder Option Problem Please Help
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
08-12-2006, 05:13 PM
Originally Posted by AshishSharma
i have run the symantec antivirus ,to cleanup the virus thread ,but i did not get any virus,
pl. help me again
suraj
__________
when i typed "regedit.exe" on going "run " ,it ask me registry editing has been "disabled" by your administrator,even i log on through administrator to my computer.
pl help me
thanks
suraj
Reason: Automerged Doublepost
08-12-2006, 07:11 PM
Distinguished Member
click http://www.kellys-korner-xp.com/xp_tweaks.htm and go to tweak number 129or maybe some other. download it, double click on it and add to registry.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
08-12-2006, 07:54 PM
Microsoft MVP
Its 100% a virus problem, just scan ur computer with a good av
09-12-2006, 09:14 AM
Originally Posted by anandk
HI
when i browse the above http://www.kellys-korner-xp tweak.htm ,it shows
another problem "registry editing has been disabled by your administrator." even i log on as a administrator.
pl give me another formula if possible. so that i can .... i donot want to format my system.
suraj
09-12-2006, 10:15 AM
Originally Posted by suraj
HI
suraj
to enable ur registry editor :
Click Start, Run and type this command exactly as given below: (better - Copy and paste)
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Pol icies\System /v DisableRegistryTools /t REG_DWORD /d 0 /f
source http://windowsxp.mvps.org/tweakuirest.htm
after enabling ur registry editor thus, try to apply the said kellyskorner tweak.
Microsoft® MVP
09-12-2006, 02:32 PM
Microsoft MVP
Guys! There is no benefit in solving this by just enabling regedit and folder options.
I hv seen this problem so many times in computers, its bcoz of a virus infection. Just scan ur computer with a good anti-virus, such as avast! or NOD32 or Kaspersky and it'll remove the virus
Also pls post ur HijackThis logfile
09-12-2006, 03:19 PM
The problem may be from either side. Might be registry problem or Virus problem. It's hard to pin point one without proper data.
Post HijackThis log file report here for analysis.
Kiran Kumar R
09-12-2006, 04:15 PM
HELLO DEAR sir/ma'am
i did the same thing according ur instruction.when i typed "REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Pol icies\System /v DisableRegistryTools /t REG_DWORD /d 0 /f " on going run ,a command windows seen but it immediately disapeared.
my system connected to "LAN". ,BUT i was able to view that folder option in toos before ,. another problem i have seen when i go to the local security policy ,and click it shows
Security templates
The group policy security that apply to this machine could not be determined .
The error returns when trying to retrieve these setting from the local security policy database.
(%windir%\security\database\secedit.sdb)was.the parameter is incorrect.
All local security setting will be displayed , no indication will be given as to whether or not a given security setting is defined by group policy.
Any local security setting modified through this user interface may subsequently be overridden by domain level policies. "
now what should i do then?
09-12-2006, 04:20 PM
Download 'HijackThis'
Then run that program on your system. It gives a report.
Copy and Paste that report content here
Kiran Kumar R
09-12-2006, 04:22 PM
Dear sir/ ma;am
i do agree with u , but my pc was slow before so i doubtly instaled some software to remove the virus..now i should installed another antivirus software?
11-12-2006, 05:23 PM
DEAR HELLO
IT SAYS "the compressed (zipped folder) is invalid or corrupted
thanks
suraj
11-12-2006, 05:29 PM
Commander in Chief
Redownload it and try.
Harsh J
www.harshj.com
11-12-2006, 05:43 PM
DEAR HELLO
thanks
suraj
It's a small program. Sometimes downloads do get corrupted. Download once more and paste the log report here. And please stop writing the replies in letter format. Just be clear cut with info, avoid using Dear...etc.
Kiran Kumar R
12-12-2006, 10:20 AM
Hi...thanks A Million.
__________
Thanks A Million To Everybody .
At Last I Scaned My Computer Through Bitdefender Anti.vir
I Got It Done
Suraj
__________
Originally Posted by kenshin1988
Open registry editor go to
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\
Create a new DWORD value, or modify the existing value named "NoFolderOptions" and set it to equal "1" to hide the options or "0" to show the options.
Log-off or restart Windows for the changes to take effect.
Source http://www.winguides.com/registry/display.php/619/
THANK U........
__________
A VERY MUCH THANK U..
SURAJ
Search this Thread |
