Old 09-12-2006, 11:00 AM   #1 (permalink)
Kiran.dks's Avatar
Default FREEWARE DOWNLOADS: Useful VIDEO Utilities Pack !!
Here is a compilation of all the Video tools you ever need.
DownUTube 2.0
Save streaming videos from internet
Download: DownUTube 2.0
Size 425Kb
  • Searching the web sites (Searcing is done within the program, not openin a browser to do the search),
  • Downloading the clips (including MMS streams),
  • Keeping looked clips in cache,
  • Showing clips' pictures,
  • Getting all available RSS feeds,
  • Looking the pages that contains clip information,
  • Keeping track of downloaded and deleted clips,
  • Downloading more than one clip at the same time
  • Sending your clips and their links to a friend (With system's default mail manager or without).
Please use the videos for personal use only.
More Info: Mamusoft
Windows Media Encoder Beta 1
Download: Windows Media Encoder Beta 1
Size 4.48MB
Windows Media Encoder Studio Edition Beta 1 is an exciting new addition to the Windows Media tools family. It is a powerful tool for video professionals, optimized for the creation of high-quality offline encoding using Microsoft’s implementation of the VC-1 video standard (WMV9). Windows Media Encoder Studio Edition Beta 1 provides the key features necessary to create next-generation video content and capitalize on the growing importance of scenarios around optical media and video-on-demand. With the final standardization of VC-1, “Studio Edition”, will prove to be an invaluable tool for the offline encoding community.
  • Segment-based re-encoding
  • Full-bit-depth support
  • Hardware acceleration
  • ISAN & Ad-ID support
  • Support for multiple audio tracks
  • Encoding from multiple audio and video sources
  • Graphical bitstream analyzer
More Info: Microsoft
DVD Genie 4.10
Unlock your software DVD player to play any region's DVDs.
Download: DVD Genie 4.10
Size 323KB
  • DVD Tweaking and Enhancement tool
  • It allows you to enable many undocumented or hard to find options through a simple and easy to use user interface
  • only supports region free DVD drive. If your DVD drive is region protected (RPC-2), you should try DVD Region-Free to watch all region DVDs.
Please note: all DVD drives as of 1 Jan 2000 is RPC-2 which means you can only switch the DVD drive's region for 5 times.
Most of the popular Software DVD Players are supported by DVD Genie along with certain additional features such as the Widescreen Zooming and certain Windows specific functions.
More Info: Inmatrix
CodecInstaller 2.1
Detect and recommend codec for playing
Download: Codec Installer 2.1
Size 623.15KB
  • detect which Audio&Video codecs are installed on your system and that suggest you to install the ones necessary to correctly view the movie it is distributed with,
  • designed to be burned on a CD together with a compressed video, to be always able to play them. The users who receive the CD, with a single tool with a simple and intuitive interface, can check if the necessary codecs are already installed and up-to-date and with just a click can install the ones required.
  • Who distributes videos on CDs can include this program to be sure that who have to see the video, will have all the necessary codecs installed./LIST]
  • complete list of the installed codec and detailed informations on them. Since version 1.3, contains a MovieLauncher that displays informations about the distributed video file (author, plot, director...) Since version 1.4 can analyze avi files. It detects: width/height and ratio, lenght, video codec, framerate, size, bitrate, total frames
More Info: Jockersoft
VideoBase 2.1
Archive your DVD, VHS, VCD, DivX and DVD-R collections
Download: VideoBase 2.1
Size 587.62KB
  • archives your DVD, VHS, VCD, DivX and DVD-R collections.
  • sort, search and filter them, and print out listings in text, HTML or XML format. You can also give them ratings.
Advanced video editing 2.0.0.0
Edit all your Video
Download: Advanced Video Editing 2.0
Size 11.13MB
  • Extract Single Video Frames to Image Files
  • Powerful Video Editing that supports editing video files to extract the individual image frames.
  • Supports AVI to BMP, AVI to GIF, AVI to (PNG, JPEG, JPG, EMF, WMV, BMP, and more). Video editing (Supported formats AVI to GIF, AVI to PNG (Portable Network Graphics), AVI to JPEG, AVI to TIFF, AVI to EMF, AVI to WMF). Easy to use (just one click of a mouse.
MPEG Parser
View MPEG internal structure and correct errors
Download: MPEG Parser
Size 878KB
MPEG Parser is the program for viewing of internal structure of MPEG-files. It can view fields of structures of MPEG file consists. MPEG Parser show such data about MPEG file: Resolution, Frame rate, Size, Aspect ratio, Bitrate ... Utility allows correct errors in MPEG, use for it menu item "Save corrected...", you can save internal structure in text file via menu item "Save MPEG information...".
AutoScreenRecorder 2.0
Save your screen activities into video files
Download: AutoScreen Recorder 2.0
Size 0.8MB
AutoScreenRecorder 2.0 Free is a completely free screen recorder to save your screen activities into video files. It is free for unlimited personal and business use. It has no expiry date and can be distributed with free of charge.
Free iPod Video Converter 1.32
Convert all popular video formats to iPod video
Download:Free iPod Video Converter 1.32
Size 1.65MB
Free iPod Video Converter provides an easy and completed way to convert all popular video formats to iPod video. You can enjoy DVD/VCD and AVI, MPEG, WMV, RM, RMVB, DivX, ASF, VOB video files in your iPod with few clicks. The program is a freeware and does not contain any form of malware.
Kiran Kumar R
Kiran.dks is offline
Old 09-12-2006, 01:55 PM   #2 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Default Re: FREEWARE DOWNLOADS: Useful VIDEO Utilities Pack !!
Nice info. Thx friend.
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 09-12-2006, 07:58 PM   #3 (permalink)
Kiran.dks's Avatar
Welcome!
Kiran Kumar R
Old 09-12-2006, 08:05 PM   #4 (permalink)
Tech Geek's Avatar
Thanks for the information.
Tech Geek is offline
Old 10-12-2006, 11:10 AM   #5 (permalink)
>>>>>Monkey Power<<<<<
shivkumar's Avatar
thanks kiran for sharing such good info.
If you want to be happy, be.
shivkumar is offline
Old 10-12-2006, 11:11 AM   #6 (permalink)
Kiran.dks's Avatar
Default Zilla Free Audio Converter-Extractor
Zilla Free Audio Converter-Extractor 5.0
Convert between audio formats, extract audio from Video
Download: Zilla Free Audio Converter-Extractor 5.0
Size 0.12MB
Converts audio formats from one to another, extract audio from video or record audio to HD. Audio Converter is able to convert(audio encoder / decoder) audio files from one format to another directly from Explorer with ID3v2 Tag editing and new Mp3 (Lame) support. Converts (to/from) WAV PCM ( WAV sound files ), MPG, MP1, MP2, MP3 ( MPEG Layer-3 ), WMA ( Windows Media Audio ), ALF2, ADPCM, GSM, G.726, DSP, A-LAW, ACM.Records from mic or cassette.
Kiran Kumar R
Old 10-12-2006, 12:44 PM   #7 (permalink)
Tech Geek's Avatar
^^This is what i wanted.
Old 10-12-2006, 04:49 PM   #8 (permalink)
anilmail17's Avatar
cool yaaar this is a complete freeware multimedia package. Thanks
anilmail17 is offline
Old 11-12-2006, 10:07 PM   #9 (permalink)
Kiran.dks's Avatar
I appreciate your feedback! Checkout for more good ones in coming days.
Kiran Kumar R
Old 11-12-2006, 10:11 PM   #10 (permalink)
ketanbodas's Avatar
^Dude ur posts rock Thanks.
Life is like a game - Enjoy playing it.
ketanbodas is offline
Old 13-12-2006, 05:10 PM   #11 (permalink)
Kiran.dks's Avatar
swf >> avi Converter 1.0.2027
Convert Flash Video to avi Video
Download: swf >> avi Converter 1.0.2027
Size 1.05MB
swf>>avi is a freeware dedicated to Flashtm .swf files to .avi conversion. swf>>avi is productivity tool. You can batch convert swf files and manage conversion profiles.
Here are some key features of "swf avi":
· Batch convert swf files to avi
· Create custom conversion profiles
· Set swf input format and avi output format
· Set output frame rate
More Info: Click here
Kiran Kumar R
Old 31-12-2006, 08:39 AM   #12 (permalink)
Kiran.dks's Avatar
Default Video Converters
Any Video Converter
Convert any Video formats for iPod, PSP, 3GP phone, MP4 player, DVD movie and More!
Download: Any Video Converter
Size 11.5MB
Any Video Converter is an All-in-One video converting tool with easy-to-use graphical interface, fast converting speed and excellent video quality. It allows you to effortlessly convert video files between every format, for FREE! It can convert almost all video formats including DivX, XviD, MOV, rm, rmvb, MPEG, VOB, DVD, WMV, AVI to MPEG-4 movie format for iPod/PSP or other portable video device, MP4 player or smart phone. It also supports any user defined video file formats as the output. Any Video Converter makes it easy for anyone to enjoy any format video with your iPod, PSP, mobile phone or MP4 player.
SUPER © Video Converter
Universal Player Encoder & Renderer
Download: SUPER © Video Converter
SUPER © IS UNIVERSAL as it supports a wide variety of input/source file format to play
or encode (to & from) without any additional third party software.
Supported input source file formats are:
- Video format: 3gp/3g2(Nokia,Siemens,Sony,Ericsson) asf, avi (DivX,H263,H263+,H264,XviD,MPEG4,MSmpeg4 etc..), dat,
fli, flc, flv (used in Flash), mkv, mpg (Mpeg I,Mpeg II), mov(H263,H263+,H264,MPEG4 etc..), mp4(H263,H263+,H264,MPEG4), ogg,
qt, rm, ram, rmvb, str (Play Station), swf (Flash), ts (HDTV), viv, vob, wmv
- Audio format: ac3, amr, mp2, mp3, mp4, mpc, ogg, ra, wav, wma
- AviSynth Script Files: avs. Let you specify advanced encoding commands using AviSynth scripts!
Kiran Kumar R
Old 03-01-2007, 11:29 PM   #13 (permalink)
Rockstar11's Avatar
thanks man
good job
Rockstar11 is offline
Old 04-01-2007, 12:32 AM   #14 (permalink)
a_g = JPKN
s18000rpm's Avatar
thanks a lot kiran.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 04-01-2007, 08:21 AM   #15 (permalink)
TheSaint
NucleusKore's Avatar
Thanks
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 05-01-2007, 08:24 PM   #16 (permalink)
Kiran.dks's Avatar
Welcome everybody!
Kiran Kumar R
Old 19-01-2007, 03:58 PM   #17 (permalink)
Good video tools. Thanks. downloaded most of them
Mahesh_Bendale is offline
- by Krow
