Re: How to Access?
^^ no not shared cable connection ... its like most isps hav only 1 hub for a certain area so if ur office machine and ur home machine is on the same hub then using this software u can share stuff ...... its like lan gaming .... me and my frenz share stuff using this funda (used to) v all hav same isp .... live in the same vicinity 1 person has installed hub software v all connect to his machine thru rmdc, odc and share .....
at times even if ur net account has expired but the isp has still plugged u to the hub ie. not disconnected u from the lan sharing takes place
@sourav hub bole toh install ynhub on ur machine and ur machine becomes hub for ur private network
http://beingmanan.com
