Old 04-01-2005, 12:46 PM   #1 (permalink)
Default northwood or prescott
which is better the 3.0 Ghz northwood processor or the 3.0 Ghz Prescott for the 915 Mobo
Not worried abt heat just want performance
shriekers is offline
Old 04-01-2005, 01:23 PM   #2 (permalink)
darklord's Avatar
915 based motherboards are generally LGA775.If you are buying a LGA775 based board and looking for a CPU for it,then these chips are available only in Prescott series.
Northwood core seized at Socket478.
darklord is offline
Old 04-01-2005, 01:59 PM   #3 (permalink)
ASUS does have a 915 mobo for the Socket478 . Any how its more logical to go in for the Prescott series due to the large cache and thus a better performance. Yes the Prescott series is not good for overclocking as the heat is a big problem. My advice go for the Prescott series.
**** happens
pradeep_chauhan is offline
Old 04-01-2005, 03:50 PM   #4 (permalink)
so it's better i go for a prescott rigt is there any price difference
Old 04-01-2005, 08:31 PM   #5 (permalink)
mine is a prescott!!
nd havnt faced ny heating prob. with it ... ((continues running for 48hrs...which included heavy games,brought the temp to 46c!!))
courtesy siSoft Sandra!!
grinning_devil is offline
Old 05-01-2005, 09:27 AM   #6 (permalink)
darklord's Avatar
Hey Grinning,
btw which board are you using right now? :roll:
darklord is offline
Old 05-01-2005, 09:41 AM   #7 (permalink)
I saw a rescue kit for prescott while reading some CPU reviews. One can google it to find it.
From what I saw, the kit looked like a First Aid Box. It had a USB fan to provide additional cooling for CPU and a Blank CD to backup important data, says prescott is not as immune to viruses as it should be.
Lastly, it was interesting.
sharon is offline
Old 05-01-2005, 07:44 PM   #8 (permalink)
my mobo . MSI 915P Neo2 Platinum
