Old 06-12-2006, 07:30 AM   #1 (permalink)
Default some trojan or wat
i hav this wierd problem plz help me...
i hav formatted my sys 15 times form past a month....becoz wenwevr i connect to the internet
there's constant upload and donload of data..i am using home 500 of bsnl so this is annoying..
i guess generic host process is behind it..i hav tried all softwares from za to norton 05 updated.
but no avail..even wen i double click the net..two computer come in taskbar and wen i chek the
status the kb's are moving up and down so fast,..so even if i stay idle on some site for a
half an hour i get sharged with 10-12 mbs..plz help..goddamit i ams stuk..i hav even
changed from win xp to sp1 and now to sp2..but still prob..
bsnl line is perfectly ok...sys has probs
i don\'t suffer from insanity....
i enjoy every moment of it..
Poseidon Rules
nishant_garg89 is offline
Old 06-12-2006, 07:51 AM   #2 (permalink)
Kiran.dks's Avatar
Default Re: some trojan or wat
Oh man! 15 times!! You are messed up dude!
Okkk.. You said you have installed Norton and Zonealarm, but you need a antispyware and firewall too! I suggest Windows Defender or Spybot 'search & destroy' Antispyware software. Regarding firewall, go for Zone alarm firewall.
Firewall is a must to avoid intrusion.
Kiran Kumar R
Kiran.dks is offline
Old 06-12-2006, 09:21 AM   #3 (permalink)
Distinguished Member
anandk's Avatar
pls post ur hjt logfile here so that someone can have a look at it. else u can also post it at www.hijackthis.de and get it auto-analysed. only then will we really be able to isolate the problem.
btw i hope its not ur windows downloading updates, just chk it pls.
generally speaking, yes use a fully updated xp/sp2 plus have an av, ani-spy, fw, when connecting to the net.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
- by Krow
